Can u wire up an obd2 dizzy to work on obd1 motor i have the clips
Old Feb 24, 2005 | 09:00 AM
1stealthls's Avatar
Default Can u wire up an obd2 dizzy to work on obd1 motor i have the clips
if so does anyone know how to do it/
thanx joe
Old Mar 9, 2005 | 08:44 AM
1stealthls's Avatar
Default Re: Can u wire up an obd2 dizzy to work on obd1 motor i have the clips (1stealthls)
ttt
Old Mar 9, 2005 | 02:38 PM
SQ is the SQUAD's Avatar
i think i might of dont it befroe, cant exactly rember but look at the 2 dizzy's the wires should be the same color code, cut and match, thats what i did
Old Mar 10, 2005 | 07:25 AM
sleeper96's Avatar
Default Re: Can u wire up an obd2 dizzy to work on obd1 motor i have the clips (h0ndavtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h0ndavtec &raquo;</TD></TR><TR><TD CLASS="quote">i think i might of dont it befroe, cant exactly rember but look at the 2 dizzy's the wires should be the same color code, cut and match, thats what i did</TD></TR></TABLE>
yep,I've done it before,just cut and match.
Old Mar 10, 2005 | 10:05 AM
zman's Avatar
Default Re: Can u wire up an obd2 dizzy to work on obd1 motor i have the clips (sleeper96)
I am using an obd2 gsr dizzy on my obd1 b16. All of the colors matched but 2. I will go check my car on which two didn't match later.
Its super easy, just make sure to solder and shrink wrap all connections.
When i first put the dizzy in, i just kinda depinned one of the plugs and plugged the wires (pins) into each other without the actual plugs on...if you can imagine this. And one of the wires came loose while driving causing my car to run like a total bag of ****.
laziebun
Dec 28, 2008 03:22 AM
crx18c1
Nov 5, 2007 07:43 AM
Cyphear
Jul 13, 2007 03:58 PM
ham
11
Dec 24, 2006 10:14 AM
Scubster
Sep 28, 2004 11:29 PM
