greddy td04 kit?
hey guys i have a td04 greddy kit,i had fully adjusted to 8lb boost,is there anyway i can boost higher?and will i get it to boost higher,and what do i need to do?thnks guys.
Manual or electronic boost controller. If the wastegate actuator is set at 8 PSI, you can easily go to 16 with a MBC. Will the engine survive? Maybe if you get it tuned right.
ok i got it to boost at 12lbs by adding washers,but now everytime i reach boost my motor starts make popping noise,now whats wrong with it?advice please,thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAE »</TD></TR><TR><TD CLASS="quote">ok i got it to boost at 12lbs by adding washers,but now everytime i reach boost my motor starts make popping noise,now whats wrong with it?advice please,thanks</TD></TR></TABLE>
Dont push it anymore ... go tune it .. or soon you'll be driving another car until you fix that one ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAE »</TD></TR><TR><TD CLASS="quote">oh and also if i upgrade my fuel pump,do i have to upgrade my injectors too or can i stay with the stock injectors?thanks</TD></TR></TABLE>
You drive 12psi with stock fuel pump and injectors ... oh man .... Anyway, get fuel pump and injectors at the same time
You should've done more reserch before turboing a car....
Stock injectors @ 12psi = motor pieces on road in a couple days.
My fuel pump is still fine.. .450s at 10lbs... you just need injectors and something to control them.
