Buying used rims' and lip has a scuff
Old Feb 24, 2005 | 04:36 AM
spicoli's Avatar
Default Buying used rims' and lip has a scuff
I was just wondering what i could do to check if the scuff is detrimental to the performance of the rim. There is a leak in the sidewal of the tire and i'm not sure if it's the seal on the rim or the tire itself
Old Feb 24, 2005 | 04:50 AM
Ricey McRicerton's Avatar
Default Re: Buying used rims' and lip has a scuff (spicoli)
I'd be very wary about that. You could always take it to a rim shop and have them re-mount the tire. It should only be like 10 bucks.
Old Feb 24, 2005 | 05:23 AM
fakemike's Avatar
Default Re: Buying used rims' and lip has a scuff (Ricey McRicerton)
You need to find out if the leak is a result of the scuff or if there is a hole in the tire. I the rim is not holding air, you would need to get the rim professionally repaired which will cost at least $50 (if you could do it locally, otherwise you have to pay to ship the rim also).
B_Swapped93
Apr 12, 2014 06:51 PM
j0keefe21
10
Jan 16, 2009 07:00 PM
vdub08
Jan 18, 2005 06:52 AM
sniperslayer
Sep 28, 2004 04:10 PM
rollin_DC4
Mar 11, 2003 05:05 AM
