quick tire question.
my tire seems like it's flat. I recently added air and for a few seconds, the tire looked "normal." Now, the tire seems to be on the verge of popping. Is it becasue the engine is heavy? Oh, and i do not have any holes/punctures on ne of my tires. Im just wondering if this is ok because both my back tires look "normal."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isaldjgxi »</TD></TR><TR><TD CLASS="quote">my tire seems like it's flat. I recently added air and for a few seconds, the tire looked "normal." Now, the tire seems to be on the verge of popping. Is it becasue the engine is heavy? Oh, and i do not have any holes/punctures on ne of my tires. Im just wondering if this is ok because both my back tires look "normal." </TD></TR></TABLE>
get a tire pressure gauge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Preludeguy »</TD></TR><TR><TD CLASS="quote">...Who is responsible for giving you a license?
, But yea like Bad-Monkey said, just get a tire pressure gauge
lol. tire guages..probably less than 5 bucks.
</TD></TR></TABLE>lol. tire guages..probably less than 5 bucks.
the tires in the front are going to look lower in pressure than the back because of the weight of the motor. get a tire pressure gage to check them.
Another thing- don't forget that you're going to get different readings depending on when you looked at your tires. If you check them cold, you'll obviously have different readings than if you check them hot. Could be why you said your tires were "on the verge of popping". I know it's something that should be obvious, but it's always the small things that turn into major problems.
