driving turbo'd w no boost
Can i drive w my turbo spinning, oiled and everything, but just diconect one of the charge pipes? i need my car for a day or two before it gets tuned and dont wanna screw anything up. Will i be okay? thanks.
Who is Mr Robot?
as long as you dont beat on it and drive carefully, the risk you take with no charge piping is that you risk overspinning the turbo, which will damage the turbo
you should be fine, i know a kid with a galant thats been driving like that for about a month! because he doesn't have enough fuel to compensate for boost, and he's been fine.
or you can just shift before you boost.you can also take the spring out of the wastegate.
you could suck something up through the piping unless you put a filter or something on it
i dont know if im totally right but i believe if you just let your turbo spin freely it can damage it
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">yea, I would definitley just put the pipe on there, and just be responsible with it, you can drive without touching boost.. I do it all the time.</TD></TR></TABLE>
thats because you drive like an old lady
jk
jk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx »</TD></TR><TR><TD CLASS="quote">yea, on second thought i think im going to just leave the wastegate off, that cant hurt can it?</TD></TR></TABLE>
Better to do that then riding around with your charge piping disconnected.
EDIT: oh yah, like wantboost said below...you're not planning on taking the actual wastegate off are you? You dont wanna do that. IIRC you can remove the spring it when you wont boost at all.
Modified by BlueShadow at 10:29 PM 2/23/2005
Who is Mr Robot?
dont take the whole wastegate off, just remove the top of the wg and pull the spring out and replace the top
yea i know i would, but ive been doin that for 3 weeks =/ i think ill just remove my spring.
BTW why is it bad to go w no wasteage?
isnt it the same thing as removing the spring?
You can take the car to 7500 RPM and not hit boost - it's all modulated with throttle position - if you don't give it more than 1/4-1/2 throttle, you won't build boost.
If you removed the wastegate completely, you'd have a 1.5" hole dumping exhaust gas out your manifold into the engine bay. That might tend to melt things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chihuahuamanx »</TD></TR><TR><TD CLASS="quote">Can i drive w my turbo spinning, oiled and everything, but just diconect one of the charge pipes? i need my car for a day or two before it gets tuned and dont wanna screw anything up. Will i be okay? thanks.</TD></TR></TABLE>
if you are running a decent basemap then boosting a few pounds isn't going to hurt anything. Just drive it normal.
i've driven my car with stock injectors, stock fuel system, stock ECU with the turbo on. It was fine because i didn't boost at all. I was super slow accelerating on the freeway though haha.. you can go past 3k rpms just as long as your gas pedal is only pressed down like 10-20 percent... just watch your boost gauge and you'll be fine.
Black R
Feb 25, 2005 11:18 AM
