How do YOU use your staging brake?
Old Feb 23, 2005 | 06:08 PM
lilmex's Avatar
Default How do YOU use your staging brake?
I'm just wondering what the proper way to use it. I've heard that you put it in 1st, hold in the lever, rev to where you want, then release the lever when the light turns green.?. I don't know. I just want to know the correct way to do it.
Old Feb 23, 2005 | 08:14 PM
A train's Avatar
Default Re: How do YOU use your staging brake? (lilmex)
i use a line lock hooked to my two step button so it releases whe i drop the button.
Old Feb 27, 2005 | 03:31 PM
lilmex's Avatar
Default Re: How do YOU use your staging brake? (A train)
Anybody else?
Old Feb 27, 2005 | 04:18 PM
Kataku2K3's Avatar
Just release it when you launch (ie. let out the clutch), unless you've got an auto trans or something...
Old Mar 1, 2005 | 05:04 PM
lilmex's Avatar
Default Re: How do YOU use your staging brake? (Kataku2K3)
cool.
Old Mar 1, 2005 | 08:06 PM
mrbsponge's Avatar
i am ghetto and use the e-brake!!!!!!!!
i just let the clutch out a little enough to pull a tad, pull up the brake and start building boost
Old Mar 2, 2005 | 02:25 AM
hondaguyef's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">i am ghetto and use the e-brake!!!!!!!!
i just let the clutch out a little enough to pull a tad, pull up the brake and start building boost</TD></TR></TABLE>
Same here(It's the same concept as a staging brake though). I use mine to pump the car forward until it is staged and then pull up harder. When it's time to go, I let the E-brake down, let out the clutch and grab onto the shifter (all in one smooth motion)
Phil
Old Mar 3, 2005 | 04:55 PM
lilmex's Avatar
Default Re: (hondaguyef)
Thanks you guys.
kornerk12
May 12, 2015 02:34 PM
rogueeg6
May 10, 2011 10:56 PM
Slidin'Sidewayz
Honda Motorcycles
16
May 20, 2008 03:00 PM
jxhxb
25
Dec 7, 2007 07:00 AM
MostlyR
Feb 9, 2005 12:39 PM
