is it possible to swap an integra type-r engine in a civic
Old Jan 19, 2002 | 06:25 PM
DOHC_SiDe's Avatar
Default is it possible to swap an integra type-r engine in a civic
is it possible to swap an integra type-r engine in a civic. is there enough room to fit it
Old Jan 19, 2002 | 06:28 PM
95GS-R's Avatar
Default Re: is it possible to swap an integra type-r engine in a civic (DOHC_SiDe)
Ok ... I'll bite.
Yes ... it is called a hybrid, you can find more information on this in the hybrid forum.
The Civic can take b16 (vtec civic motors), b18 (from teg ls to type r), even b20's from the CR-V.
Old Jan 19, 2002 | 07:47 PM
Vazquez911's Avatar
Default Re: is it possible to swap an integra type-r engine in a civic (95GS-R)
No, it won't work... Didn't you know that a Type-R motor is an Acura motor... and Acura motors don't fit in Hondas? You can only use REEL Honda motors in Hondas... Cause if it is NOT a Honda motor you will be a ricer by using a NON-HOnda motor. If you want a bigger motor for your Honda, why don't you try fitting a REEEAL Honda Odyssey MOTOR... that would give you MADDD Honda torque yo... and still be VTEC!!!
Seriously... forget Acura stuff... Honda all the way!
*disclaimer - If you took this seriously... sell your soul to the devil now, and consider yourself an idiot.
Old Jan 19, 2002 | 08:02 PM
bigTom's Avatar
Default Re: is it possible to swap an integra type-r engine in a civic (Vazquez911)
yes it is possible... and many people have done it already... read more about it in the hybrid forum... u can even put a prelude motor into a civic but u need custom mounts for that and they do make the car a little front-heavy which basically screws up the handling of the car unless u mess with the suspension...
Old Jan 20, 2002 | 07:57 AM
JCushing's Avatar
hmmmm id say if you have to ask then no
you should just buy some spoon motors and hook that up wit NOS
heres a good resource though http://hybrid.honda-perf.org/
Old Jan 20, 2002 | 08:35 AM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Default Re: is it possible to swap an integra type-r engine in a civic (Tom)
Does anyone know how you would "mess" with the suspension to make the car handle properly with a heavier engine in the front. I'm thinking the only way to do it is to make the front adjustments different than the rear on adjustable shocks, and maybe put different spring rates. But then if the latter is the case, which spring rates would offer the "perfect ride". Anyone have good experience with this?
Old Jan 20, 2002 | 08:57 AM
JCushing's Avatar
Default Re: is it possible to swap an integra type-r engine in a civic (98SILVERGSR)
i would also have to say relocating the battery to the trunk and taking as much outa the front of the car as possible with heavy rates in the back with a big rear sway bar
Old Jan 20, 2002 | 09:04 AM
sa21199's Avatar
use springs with a spring rate for a lude
Old Jan 20, 2002 | 10:29 AM
sutrusu's Avatar
Default Re: is it possible to swap an integra type-r engine in a civic (JCushing)
direct port nahs, with a t66 turbo!!
Old Jan 20, 2002 | 11:32 AM
alexboy's Avatar
You have alot to learn my son. Seriously check Hybrid Board there is no reason to own a civic (with the exception of the si )but to do a motor swap
Yonutzz
Mar 15, 2018 02:24 PM
elhartd
18
Nov 22, 2010 05:35 PM
Nick31488
31
Oct 31, 2004 07:10 PM
