Just bought GReddy 15G and JRC 6" FMIC, what HP I'll have on D16Z6 ?
Old Feb 23, 2005 | 03:31 PM
miro_gt's Avatar
Default Just bought GReddy 15G and JRC 6" FMIC, what HP I'll have on D16Z6 ?
The order should come in 3 days ... the car is all stock. ... So, what is your guess, will I pass 150HP ? .. the engine has 103K miles ... oh, and what would happen if i put 87 octane gas in the car ? I think the kit comes set to 5-6psi or so
Old Feb 23, 2005 | 03:32 PM
MooreBoost's Avatar
Default Re: Just bought GReddy 15G and JRC 6" FMIC, what HP I'll have on D16Z6 ? (miro_gt)
162.7 whp.
Old Feb 23, 2005 | 03:36 PM
miro_gt's Avatar
Default Re: Just bought GReddy 15G and JRC 6" FMIC, what HP I'll have on D16Z6 ? (MooreBoost)
damn that sounds good to me ... any other suggestions ? ... I got 17" wheels, not sure if that counts somehow ...
Old Feb 23, 2005 | 03:37 PM
MooreBoost's Avatar
17's actually make power believe it or not.
171.2 whp!
Old Feb 23, 2005 | 03:51 PM
Timmay's Avatar
i would run at least 91 octane
9-10 lbs should get you 200 whp with a little bit of tuning
6 lbs is about 150-160 whp i would think
Old Feb 23, 2005 | 04:02 PM
miro_gt's Avatar
Default Re: Just bought GReddy 15G and JRC 6" FMIC, what HP I'll have on D16Z6 ? (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">i would run at least 91 octane
6 lbs is about 150-160 whp i would think</TD></TR></TABLE>
... do you think I'll be closer to 160 WHP than to 150 ? ... we got 87,89, and 93 gas in GA
Old Feb 23, 2005 | 04:12 PM
CRXDrew's Avatar
Go w/ 93 octane.... do more research.
turbos can be a great thing... but you can't just bolt them on like an intake. Know what you're getting urself into.
Old Feb 23, 2005 | 04:16 PM
Timmay's Avatar
Default Re: (CRXDrew)
go with 93 and 160 should be the range, but its all hard to say untill you put it on and dyno it
i would get some colder spark plugs to like ngk bkr7e gapped to about .30
leave timing stock and get a FMU
or if you have the cash get neptune or hondata and tune that ****
Old Feb 23, 2005 | 05:07 PM
miro_gt's Avatar
Default Re: (Timmay)
the kit comes with that e-manage that GReddy has ... I heard that it's actualy a pretty good thing .. so why would I need hondata ?
Someone said that the stock fuel pump and injectors are good up to 7.5 psi !?!
As for the spark plugs - I'll get 2 step colder, but not sure NKG BKR7e or BKR7e-11 ... I think one is longer than the other
so my HP will be about 160, correct ? ... sounds good to me at this moment
Old Feb 23, 2005 | 05:20 PM
MooreBoost's Avatar
Default Re: (miro_gt)
The E-manage is a pretty good unit, but for what it costs, you can do alot better. If you want, you could sell it, and buy something else, such as an Uberdata setup.
If you go with either one of these setups you will need larger injectors, and a larger fuel pump, such as DSM 450cc injectors and a Walbro 255.
Old Feb 23, 2005 | 05:27 PM
miro_gt's Avatar
Default Re: (MooreBoost)
the kit comes with e-manage ... no choice for now
Old Feb 23, 2005 | 06:17 PM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miro_gt &raquo;</TD></TR><TR><TD CLASS="quote">The order should come in 3 days ... the car is all stock. ... So, what is your guess, will I pass 150HP ? .. the engine has 103K miles ... oh, and what would happen if i put 87 octane gas in the car ? I think the kit comes set to 5-6psi or so</TD></TR></TABLE>
Shut up noob
AYoungIV36
May 14, 2014 03:59 AM
Turbo_TONY
Dec 3, 2009 01:03 PM
deadline
12
Oct 12, 2006 07:50 PM
sohc dude
Dec 23, 2005 08:10 AM
jerbear!
17
Apr 7, 2004 08:16 PM
