question regarding NSX calipers on ITR
Old Feb 23, 2005 | 03:07 PM
SpoogenJay's Avatar
Default question regarding NSX calipers on ITR
would 91 NSX calipers work on an ITR (clear ITR rotors)?
Old Feb 23, 2005 | 03:09 PM
MattD@Stoptech's Avatar
Default Re: question regarding NSX calipers on ITR (HybridTypeR80)
yes
Old Feb 23, 2005 | 03:10 PM
migs's Avatar
With a few shims. Yes. Run and hide before everybody flames you because the topic has been covered many times.
I personally recommend upgrading to the Legend GS rotor, use less shims but its more rotational mass.
Old Feb 23, 2005 | 03:12 PM
Default Re: question regarding NSX calipers on ITR (migs)
pretty sure there is no need for "shims"
Old Feb 23, 2005 | 03:20 PM
migs's Avatar
Default Re: question regarding NSX calipers on ITR (El Pollo Diablo)
I know there is a need. I attempted it already and even with the Legend GS rotor, you need to shim but not as much.
Old Feb 23, 2005 | 03:21 PM
migs's Avatar
I take it back, I used the NSX caliper bracket inconjunction with the NSX caliper and it required shims, either way you look at it. I did not attempt to use the NSX caliper with the ITR caliper bracket.
I only speak for using both NSX caliper and NSX caliper bracket.
Old Feb 23, 2005 | 03:31 PM
i'm pretty sure there is no need to shim when a NSX caliper is used with an ITR bracket...but I'm t00 lazy to search.
Old Feb 23, 2005 | 04:05 PM
fangtl's Avatar
The NSX caliper works with the ITR bracket and rotor, no shims needed.
Old Feb 23, 2005 | 04:48 PM
jeff652's Avatar
Default Re: question regarding NSX calipers on ITR (fangtl)
You can do it that way (NSX Caliper, ITR bracket & rotor) but if the pads wear down to zero, you may have problems. The ITR Rotor & bracket are 23mm wide, while the NSX caliper is designed for a 28mm rotor. At full extension, the NSX caliper pistons will be extending 5mm beyond where they were designed to go.
Will this cause them to pop out and fail, leading to a loss of break pressure? If you try it let me know
I had shims made when I was running this setup. I have since upgraded to 12" front brakes with the NSX caliper and 99+ RL bracets and rotors . . .
Old Feb 23, 2005 | 04:59 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fangtl &raquo;</TD></TR><TR><TD CLASS="quote">The NSX caliper works with the ITR bracket and rotor, no shims needed.</TD></TR></TABLE>
CORRECT. i ran this setup for many years (just sold it actually) with no piston popping issues....
Old Feb 23, 2005 | 06:37 PM
blackntegra's Avatar
Default Re: question regarding NSX calipers on ITR (Rodney)
yep i agree.
no shims needed for stock rotors
CroSi
Suspension & Brakes
12
Aug 7, 2017 10:03 AM
I like my R
Jan 22, 2013 07:21 PM
Toy Civic
Dec 13, 2011 05:12 PM
sumyungguy
33
Mar 30, 2006 06:59 PM
SilverDc2
Jun 4, 2003 07:46 AM
