97 Ls motor into 00 si
Old Feb 23, 2005 | 02:28 PM
SoldMyEM1's Avatar
Default 97 Ls motor into 00 si
I've got a 00 si that I am currently building a motor for and have the chance to get a 97 ls motor for really cheap. I am just planning on putting the ls motor in for a few months while my motor is being built. I did a quick search and didn't find anything. My question is what all would be nessecary for this swap? I've been told that all the wiring will plug right in if i use my engine harness, I just use the ls dist. and get a obd2 to obd1 harness and run the ls ecu, is this true? If not what wiring changes will be needed..TIA
Old Feb 23, 2005 | 03:18 PM
sockvtec's Avatar
Default Re: 97 Ls motor into 00 si (IheartMyEM1)
every car from 95 and up is obd2, so why would you need an obd 1 harness for a 97 motor?
Old Feb 23, 2005 | 03:19 PM
SoldMyEM1's Avatar
Default Re: 97 Ls motor into 00 si (Burns)
To use an obd1 ls ecu because I don't think a obd2 ls ecu will plug into my si harness
Old Feb 23, 2005 | 03:44 PM
SOHCD16y8's Avatar
why did you modify your harness? it should fit
Old Feb 23, 2005 | 03:46 PM
sohcvtec1995's Avatar
Default Re: (SOHCD16y8)
96-98 obd2a 99- obd2 b. also i thought it was illegal to put a motor in a car that is older then the car. might want to find out.
Old Feb 23, 2005 | 04:09 PM
A.E Motoring's Avatar
Default Re: (sohcvtec1995)
your supposed to put a motor in thats same year or newer
Old Feb 23, 2005 | 04:12 PM
FAWKeveryb0dy's Avatar
your stock harness should plug up to a 99+ ls ecu if you didnt modify it or anything
Old Feb 23, 2005 | 04:13 PM
rasinhell's Avatar
Default Re: (FAWKeveryb0dy)
yea I think its illegal to put an older motor then ur car in ur car. You wont pass emissiosn or something
Old Feb 23, 2005 | 04:15 PM
Default Re: (The-Beast)
its because the year car was designed with certain emmision ratings from the factory. So basically 97 had certain standards and 00 has others. And emmisions get get better not worse throughout the years. So you can put a newer motor in becasue the emmisions are higher and the goverment likes that.
Old Feb 23, 2005 | 04:20 PM
ReDHaTcHyGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The-Beast &raquo;</TD></TR><TR><TD CLASS="quote">yea I think its illegal to put an older motor then ur car in ur car. You wont pass emissiosn or something</TD></TR></TABLE>
It also depends where u live , i don't think we have a law like that here... If ur using a 97 it will plug into ur harness fine but u will need a conversion harnessfor the ecu.. if u use the obd1 dizzy u will have to repin the plugs on the dizzy cause they are not wired the same as the obd2 ones.. There is also one other thing everyone else forgot to tell u , you are gonna have to use the hard block mount from the driver side off the SI motor, since the integra ones are different
Old Feb 24, 2005 | 02:22 AM
SoldMyEM1's Avatar
Default Re: (ReDHaTcHy97)
This motor is obd2. The obd2 ls ecu should plug into my si harness with no modification, also I'm pretty sure the distributor will also plug in, but could be wrong.
Old Feb 24, 2005 | 11:55 AM
Default Re: (IheartMyEM1)
but if it is a 0bd2a ecu it will not plug in fine .... the Si is 0bd2b u would need a conversion harness.......
Old Feb 24, 2005 | 12:03 PM
Dacalac's Avatar
it's just a temp engine. He's not trying to get it to pass anything. Re-read his post more carefully.
Old Feb 24, 2005 | 12:10 PM
94ls's Avatar
ls motor for what??? lsvtec or lsturbo? just curious
Old Feb 24, 2005 | 12:12 PM
Dacalac's Avatar
Default Re: 97 Ls motor into 00 si (94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94ls &raquo;</TD></TR><TR><TD CLASS="quote">ls motor for what??? lsvtec or lsturbo? just curious</TD></TR></TABLE>
once again I would advice you to re-read the original post. This is just a temp engine until he's b16 is back from the shop.
Old Feb 24, 2005 | 12:18 PM
senpai's Avatar
Default Re: 97 Ls motor into 00 si (d15 dirk)
hehe, so many ppl have ADD - huh, wat?
just do it.
might as well go obd1 and get a chipped ecu to run the ls, then burn the chip again when you get the b16 done
Old Feb 24, 2005 | 12:23 PM
Dacalac's Avatar
Default Re: 97 Ls motor into 00 si (senpai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IheartMyEM1 &raquo;</TD></TR><TR><TD CLASS="quote">This motor is obd2. The obd2 ls ecu should plug into my si harness with no modification, also I'm pretty sure the distributor will also plug in, but could be wrong.</TD></TR></TABLE>
try it out and let us know...
did anything come up when you searched in the archives?
Old Feb 24, 2005 | 12:47 PM
SlepT ej6's Avatar
to run the 97 ls ecu your gonna have to get a obd2 b to A conversion harness... the distributor plugs i think will be the same now that im pretty sure that it goes by what obd it is and not A or B.....ur harness will contain remainders of vtec wiring but just tape them off while the ls is in and i cant think of anything else... use all your mounts, ur axles and ur shift linkage and you should be goood!!
Old Feb 24, 2005 | 01:58 PM
SoldMyEM1's Avatar
Default Re: 97 Ls motor into 00 si (SlepT ej6)
Thanks for everything, Im gonna see what happens with the ecu tonight. I'll let everyone know how things go as I move on. So little time with work and school
ek9ina
Mar 13, 2014 09:30 PM
Lee_eg6si
Welding / Fabrication
Sep 22, 2007 07:22 PM
EKtypeRhaTcH
May 10, 2005 10:46 AM
Patron
Jan 2, 2002 02:43 PM
euclidEH3
Aug 19, 2001 06:35 PM
