will uncut bumpstops ruin my shocks?
Old Feb 23, 2005 | 02:26 PM
KB96VTEC's Avatar
Default will uncut bumpstops ruin my shocks?
i installed KYB AGX's and Neuspeed Sports a little over a month ago and didnt cut my bumpstops or get an alignement. i dont mind the slightly bouncy ride of the KYBs but anytime i hit a bump my car slams like hell. could this be because of the uncut bumpstops? is it worth it to take all the suspension off again to cut em? i certainly will if my KYBs are gonna be ruined.
Old Feb 23, 2005 | 02:53 PM
user 9782082308's Avatar
Default Re: will uncut bumpstops ruin my shocks? (KB96VTEC)
What do you have the shocks set to? If they're set pretty low you can set them higher till you cut the stops down some.
Old Feb 23, 2005 | 03:00 PM
street_ruler's Avatar
the bumpstops are there to keep the shock from compressing too much, you cut em and you;re gonna blow em out
Old Feb 23, 2005 | 04:02 PM
KB96VTEC's Avatar
but the car is lowered. i thought you supposed to cut em when its lowered?
Old Feb 23, 2005 | 04:59 PM
rawkus's Avatar
Default Re: (KB96VTEC)
On my Accord, when I got Eibach springs, the manual recommended cutting the bump stops down by about half. If yo have the shocks removed, you can lower (slowly) the shaft until it hits the bottom of its travel. Whatever is still sticking out (not including the threads) the bump stop should be longer then that and not capable of being squished into a space smaller then is sticking out. Hope that makes sense.
Dan
Old Feb 23, 2005 | 06:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KB96VTEC &raquo;</TD></TR><TR><TD CLASS="quote">but the car is lowered. i thought you supposed to cut em when its lowered?</TD></TR></TABLE>
nah, you can, tehy say to do that for exra travel, but it voids any warranty, and if your car is really that low, choose a shock wiht a shortened body, somthing made to go that low. when they hit that bumpstop its to keep it from overcompressing like i said. yeah its cool to ride the bumpstops under cornering and have infinate spring rates, but tehres a reason for em
Old Feb 23, 2005 | 06:01 PM
clemsoncb7's Avatar
You really should. It helps. Dont' worry, I have overhauled my suspension about 6 times now, its easy!!!
AcuraKid
Suspension & Brakes
Jun 4, 2005 05:25 AM
DaChoZn1
Apr 8, 2005 11:41 AM
exquisite
Sep 26, 2003 08:55 PM
abeaujuin
May 3, 2002 09:01 PM
EH2DX
Dec 21, 2001 07:54 PM
