Golden Eagle Benefits
Doing LSVtec as my first set-up ive been tryin to secure it as much as i can
What are the benefits to having the following:
ARP Head Studs
ARP Rod Bolts
Golden Eagle Block Guard
Golden Eagle Girdle Kit (due to adding on OEM b16 pistons for H/C)
ARP Head Studs
ARP Rod Bolts
Head studs:Less stretch,Holds the head tighter against the gasket/block than stock bolts.
ARP rod bolts:Stock ls bolts are the week point when reving higher.
Block guard:Misguided attempt at making stock sleeves more reliable.
Girdle kit:I don't generally use them,some do/some don't.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advertise »</TD></TR><TR><TD CLASS="quote">i would go with the GE headstuds as well
...a step up from the arp's</TD></TR></TABLE>
well everything i listed is installed and payed for already so i cant go back now
...a step up from the arp's</TD></TR></TABLE>well everything i listed is installed and payed for already so i cant go back now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">Then I guess I waste my time responding.
Glenn</TD></TR></TABLE>
Thanks anyway Glenn but i do have a question for you...What is the fastest E.T for an all-motor LSVtec and the most power one ever made ???
I was just browsing JHPUSA.com and noticed that they carry a Buddy Club Spec 5
Cam and i wanted to know what was the difference between that and the Buddy Club 4
Buddy Club Racing Spec IV B-Series VTEC Cams
Camshafts developed from Buddy Club's N1 endurance racing experience. Specifications: intake 306 duration, 12.3mm lift, exhaust 302 duration, 11.8mm lift. Please note supertech or buddy club valve springs are highly recommended.
Buddy Club Racing Spec V Extreme B-Series VTEC Cams
Buddy Club Racing Spec V Extreme Camshafts developed from Buddy Club's N1 endurance racing experience. Specifications: intake 312 duration, 12.8mm lift, exhaust 306 duration, 11.8mm lift. Please note supertech or buddy club valve springs and titanium retainers are highly recommended.
Im not much of a NA tech but i did notice that the duration is higher on the intake & exhaust cam and the lift is higher as well. Im still researching exactly what that means but if anyone has any info please lemme know.. Thanx in advance.
buff1110
Nov 30, 2007 12:10 PM
