removing the ek wing
Open the hatch.
Pull off the upper trim peice for the hatch.
You'll see two bolts twoards the outside edges of the car. Remove those.
Remove the two black plastic "caps" and remove the bolts underneath them.
Use some needlenose pliers or something like that to push out the small black tab in the middle of the wing from inside the hatch.
Remove the squirter feed hose and the electrical connection and you're done.
That's all done out of memory, so it might not be 100%, but it should take you less than 5 minute to get off.
VTECROAR96typeR
Nov 1, 2009 10:54 AM
meagainsttheworld
Aug 11, 2007 05:28 AM
hothatch
Jun 28, 2001 01:18 AM
