C-C5
Old Feb 23, 2005 | 08:01 AM
Ricta's Avatar
Default C-C5
Yeah i was going to get an Integra Type-R engine but its hard to find a USDM (B18C5) motor for cheap or at all. But then i saw the JDM (B18C) engine and was able to find it at numerous places for good money and low mileage but i know it would have to require a left hand drive wiring harness. So i was just wondering if their where and diff specs frome the JDM engine to the USDM. Thanks
Old Feb 23, 2005 | 08:04 AM
rough_draft's Avatar
there are so many threads on this. try searching
but off the top of my head, the final drive, jdm itr 4-1 header, higher compression
Old Feb 23, 2005 | 08:05 AM
Bbasso's Avatar
Default Re: C-C5 (Ricta)
https://honda-tech.com/zerothread?id=766629
Old Feb 23, 2005 | 08:40 AM
KOALA YUMMIES's Avatar
Left hand drive wiring harness? No.
Old Feb 23, 2005 | 09:38 AM
fullraceacura's Avatar
Default Re: C-C5 (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">Left hand drive wiring harness? No.</TD></TR></TABLE>
yep you dont need one if you turn the whole swap around, ie:tranny on driver side, hasport makes a mount for that and it really simplifies the mounting process of a JDM motor
Old Feb 23, 2005 | 09:49 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: C-C5 (itr#xxxxlives)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives &raquo;</TD></TR><TR><TD CLASS="quote">
yep you dont need one if you turn the whole swap around, ie:tranny on driver side, hasport makes a mount for that and it really simplifies the mounting process of a JDM motor </TD></TR></TABLE>
Huh?
Old Feb 23, 2005 | 09:51 AM
.RJ's Avatar
.RJ
Are you retarded?
Old Feb 23, 2005 | 09:55 AM
Jon D's Avatar
Default Re: C-C5 (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Are you retarded?</TD></TR></TABLE>
wouldn't that be awesome if he was serious..... . Gosh i hope so
&lt;---ROFLHAO
Old Feb 23, 2005 | 09:57 AM
Bradstard's Avatar
No, it's better than putting in upside down and having custom axles and exhaust manifolds made.
Old Feb 23, 2005 | 10:00 AM
Splat's Avatar
Default Re: C-C5 (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">
No, it's better than putting in upside down and having custom axles and exhaust manifolds made.</TD></TR></TABLE>
Wouldn't have to worry about header clearance then
Old Feb 23, 2005 | 10:01 AM
Bradstard's Avatar
Default Re: C-C5 (Splat)
Yes, the header goes under the valve cover then.
Old Feb 23, 2005 | 12:53 PM
Cone's Avatar
98 Spec B18C: 11.1:1 CR (USDM 10.6:1), 4.785 FD tranny w/ 4th and 5th gear ratios different. CTR cams, 4-1 tubular header w/ 2.5" collector.
the 96 Spec uses the same tranny as the USDM R, same cams as the 97-98 USDM R, and a cast iron 4-2-1 header.
Tippyman
Aug 10, 2011 08:38 PM
crazyguy
Jan 31, 2008 03:33 PM
hybridh@tch
Oct 20, 2005 08:42 PM
wizzards581
Oct 21, 2003 09:55 AM
g's integ
May 16, 2002 04:16 PM
