HELP with my LSD
Ok this is for a Sohc.. I need to know which bearings i have to buy for the OBX LSD.. I bought the Honda OEM ones but they dont fit(too small).
What have SOHC guys with the OBX Differential have used?
here are some pics
I need to solve this today or tomorrow cause were installing my clutch ,flywheel and LSD on Saturday and i need to get the wheel bearings on the differential.
thanks
Modified by fjt at 1:27 PM 2/23/2005
here are some pics
thanks
I have the same LSD installed.
this is what you need.
41312-PL3-B00 speedo gear
91005-PS1-003 Diff bearing, need 2
91002-PSO-003 ISB bearing
91216-PL3-005 ISB seal
23927-PL3-000 thrust washer
23928-PL3-000 thrust washer
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">you can use your old ones if you want.
just not a good idea. When removing them from the old diff they can get messed up and cause serious problems later.
platinum</TD></TR></TABLE>
Yeah my mechanic sees it as taking a shower and putting the same dirty underwear..lol je je je
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost »</TD></TR><TR><TD CLASS="quote">I guess I thought OBX would include them, I should have known better.</TD></TR></TABLE>
haha, yea,
that's one thing people dont relize when buying these. is that quaffe includes the new ****, and OBX does not. that's prolly how hey offset the price a little
platinum.
haha, yea,
platinum.
I called the honda parts and well it turns out they gave me the CX tranny diff. bearings(since i have a CX EK)..aparently the EX tranny has bigger bearings and share the same part number as the Integra LS differential bearings.
I put my obx lsd into a z6 tranny and had crazy clearance issuses between the casing and the diff. i had to get the shim milled down because honda did not make a small enough one. Did anyone else have this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungsohc »</TD></TR><TR><TD CLASS="quote">I put my obx lsd into a z6 tranny and had crazy clearance issuses between the casing and the diff. i had to get the shim milled down because honda did not make a small enough one. Did anyone else have this problem?
Having it as we speak with an 89 tranny.
</TD></TR></TABLE>Having it as we speak with an 89 tranny.
haha, yea,
platinum.</TD></TR></TABLE>
what does quaife include? what is the "new ****"?
haha, yea,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">haha, yea,
i wish my quaife came with new bearings. woulda saved me 120 bux.
