does the timing change or require adjustment after a valve adjustment?
Old Feb 23, 2005 | 02:35 AM
euG3dc2r's Avatar
Default does the timing change or require adjustment after a valve adjustment?
Hi all,
Just wondering if the timing changes or do u need to re-adjust the timing after a valve adjustment ...
not sure if that makes sense...
Old Feb 23, 2005 | 02:39 AM
sneakychaos's Avatar
Default Re: does the timing change or require adjustment after a valve adjustment? (euG3dc2r)
No, it should have have affected your timing by doing a valve adjustment.
Old Feb 23, 2005 | 03:45 AM
Finland's Avatar
I assume you are referring to ignition timing. No, valve lash adjustment has nothing to do with ignition timing.
crxaddikt
Mar 8, 2013 08:06 PM
555R
Jan 11, 2005 05:46 PM
hybr1d_rac3r
Mar 8, 2004 05:04 PM
SH LUDE
Oct 28, 2002 08:22 PM
SEVENSIX
Jun 12, 2002 07:31 AM
