Drain Line...I want to do this right the first time...Whats your opinion/setup??
Before the flames...I've done the searching, but still have the following question: What will be the best setup for oil supply and drain for my turbo. I'm installing your basic T3T4 on a B16A1. I've seen a lot of pre-made kits but want to know whats best. What kind of setup are you running?? Where did you get it?? What do you wish you had done...and so on. Thanks!
they're all basically the same thing just depends on how good the person that bought it, put it together and installed it. -10AN fittings and line to a -10AN weld on bung for the oil pan and you're good to go.
