What is leakdown?
Old Feb 22, 2005 | 09:18 PM
rasinhell's Avatar
Default What is leakdown?
Hi. I'm stupid. Just wondering. What is a leakdown test? What does it test and how is it done?
Old Feb 22, 2005 | 11:06 PM
John221's Avatar
Default Re: What is leakdown? (The-Beast)
A leakdown test is basically a quick test to see if there is any fault in the head or the block. Bad valves for the head....bad piston rings for the block...etc.
You'll have to have a leakdown tester in order to perform this test. Take out the spark plugs. Set whatever cylinder you want to test at TOP DEAD CENTER. Plug in the leakdown into that spark plug tube and connect your leak down tester to an air compressor. Your gauge will tell how bad the leak is.
Goodluck
wildoutwhitegsr
Sep 7, 2010 01:19 PM
sinister357
Aug 25, 2007 10:05 PM
1badteg
Jul 16, 2007 02:00 PM
IH82LOSE
Jul 31, 2004 05:20 PM
