where can i find a gm 3bar map sensor
Old Feb 22, 2005 | 05:54 PM
Zero2Sixty's Avatar
Default where can i find a gm 3bar map sensor
like the title says and i also need the pigtail to it also
let me know
Old Feb 22, 2005 | 06:12 PM
per4mance's Avatar
Default Re: where can i find a gm 3bar map sensor (Zero2Sixty)
Try a junk yard that has a bunch of later models GM cars.I found one on a trans am here at a local yard, I just cut the plug and took it, Or u can buy one new at the dealer for around 60 or 70 with discount I think.
Old Feb 22, 2005 | 06:33 PM
93LSivic's Avatar
Default Re: where can i find a gm 3bar map sensor (per4mance)
Dont goto a junk yard, you'll be wasting your time. Unless of course it has a grand national or a turbo 89 trans am cause thats what the 3bar sensors are off of.
Goto you local dealer or find the part number on the aem boards and goto gmpartsdirect.com
To the guy above me. You more than likely have a 2bar map sensor unless you pulled it off one of the cars I mentioned.
Old Feb 22, 2005 | 06:41 PM
1Bar GSR's Avatar
Default Re: where can i find a gm 3bar map sensor (93LSivic)
http://www.wiredspeedlab.com BUY IT FROM RICKY!!!
$90.00 and comes with instructions and pigtails
Modified by 1Bar GSR at 1:02 PM 2/24/2005
Old Feb 22, 2005 | 06:50 PM
Zero2Sixty's Avatar
Default Re: where can i find a gm 3bar map sensor (1Bar GSR)
link doesnt work
Old Feb 22, 2005 | 09:50 PM
PrettyLude's Avatar
lightningmotorsports.com
Old Feb 23, 2005 | 07:28 PM
1Bar GSR's Avatar
Default Re: (PrettyLude)
Sorry I guess their site is down or something if you have aim im :
Wiredspeed Ricky
or call : 18009473380 and ask for ricky!
Old Feb 24, 2005 | 12:55 AM
Dngerzone2's Avatar
Camp1320 motorsports $75 shipped with Pigtail...
Old Feb 24, 2005 | 09:23 PM
rpm11's Avatar
Default Re: where can i find a gm 3bar map sensor (Dngerzone2)
+1
Old Feb 25, 2005 | 10:23 AM
YellowCTR's Avatar
Default Re: where can i find a gm 3bar map sensor (rpm11)
I went to a junk yard here and got one off a 99 z28, so its not a waste of time if you know anything about what all gm cars have them...... not just old *** gms
Old Feb 25, 2005 | 11:14 AM
98lude-t's Avatar
Default Re: where can i find a gm 3bar map sensor (9keek9)
funny that
it makes a differnece if they are a boosted setup or n/a.
i bought one that was off of a turbo sprint and it didnt work for my setup
anytime it saw boost it shut down my motor until it saw 0 boost.
i got one off of a 89 3.8 turbo transam 25th aniversary edition and that one works fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9keek9 &raquo;</TD></TR><TR><TD CLASS="quote">I went to a junk yard here and got one off a 99 z28, so its not a waste of time if you know anything about what all gm cars have them...... not just old *** gms </TD></TR></TABLE>
so its not all the same or for old ones.
Old Feb 25, 2005 | 12:50 PM
mike1114's Avatar
Default Re: where can i find a gm 3bar map sensor (98lude-t)
Only around $70 shipped With pigtail
Old Feb 25, 2005 | 12:59 PM
hpfsi's Avatar
GM map sensors all look identical for the most part. That definately doesn't mean they are the same or even a 3-bar.
Here are the GM 3-bar part #'s:
12223861 - (-14.4psi to 31.1psi)
12219935 - (-8.3psi to 30.8psi)
16040749 - (-13.1psi to 29.3 psi)
Anything else would be one of the many different part #'s for GM 1 and 2 bar sensors. You guys are crazy if you just throw some unknown map sensor on your car
Old Feb 28, 2005 | 12:13 PM
Zero2Sixty's Avatar
what is the part number to the pigtail
PhatwhipsJDMkits
Apr 14, 2009 03:21 PM
90Rexx
Apr 4, 2008 08:54 AM
del_slow420
Jul 14, 2007 09:48 PM
Honda-Hooligan
Feb 16, 2006 06:01 PM
ebp 99 si
Jun 18, 2003 12:10 PM
