will 225/50/r15 g force drag radials fit 99 si rims?
Old Feb 22, 2005 | 05:44 PM
EGh22aEG's Avatar
Default will 225/50/r15 g force drag radials fit 99 si rims?
Old Feb 22, 2005 | 06:13 PM
dunkd's Avatar
Default Re: will 225/50/r15 g force drag radials fit 99 si rims? (EGh22aEG)
yes, plenty of people run that size
Old Feb 23, 2005 | 01:47 PM
DA9_DAD's Avatar
i'm thinking that's kinda wide....205/50/15 works very well. the wider you go (205, 225) the weaker the center of the tire gets...contact patch will not be maximized, especially for a 6.5" rim. if you had a 15x7 or 15x7.5 then the wider tire may work. you may also encounter tire rub on the fender wells....if you've dropped your car and you have camber..definitely will see rubbing occur.
tr0n9h
Oct 16, 2005 02:49 PM
greenmonster
Oct 18, 2004 04:43 PM
turbo craig
Sep 3, 2003 05:18 AM
b16ahybrid
Apr 15, 2003 06:44 PM
