code 20 electronic load detector?????
Old Feb 22, 2005 | 05:25 PM
nummbr7's Avatar
Default code 20 electronic load detector?????
I just swapped a b18a into my 91 civic , I had it running last night with no codes
tonite I installed my cv shafts and put oil in the tranny, then tried to start it
nothing just a click at some relay and a code 20 also the oil light stays on after the key is turned off
anybody got any idea or suggestions I'm all ears
Old Feb 23, 2005 | 05:43 AM
JimBlake's Avatar
Default Re: code 20 electronic load detector????? (nummbr7)
The ELD is built into the under-hood fusebox. Maybe you gotta get a fusebox with one?
That should not be related to the other problems - starter not cranking & oil light staying on. Check all your wiring...
sydag5
Acura TSX
Mar 5, 2016 12:47 PM
ballerchild
Jun 28, 2006 12:27 PM
amoarian
Sep 25, 2005 10:43 PM
SlippylesKB
Nov 12, 2003 07:21 AM
