Lower radiator hose deflating/suctioned
Is this when it's cooling down or does it do it when it's running?
When cooling down...
Check the smallest disk-seal in the radiator cap. That disk should pull down very easily. What that's for is so the system can suck coolant back in from the reservoir at the slightest vacuum. Then look for blockage in the little hose going over to the reservoir.
If it does this when running, I'm not sure. Maybe a really plugged-up radiator?
miahjera04
Sep 5, 2018 04:19 PM
The-LS
Jul 14, 2004 01:16 PM
