quick question on P30 ecu
Old Feb 22, 2005 | 02:38 PM
ek2k's Avatar
Default please tell me if i have a chipped p30 ecu pics...
please copy and paste
im sorry if the pics are huge
okay so i have an obd 1 p30 ecu that came of a eg6 but i dont know if it has a chip and from what i have researched p30 is not all that and it should have a rev limit of 8200 but i had a b16a in my coupe and with that ecu i noticed that there was no rev limit because i one time rev it to 9950 lol i only did it that once to find out where was my fuel cutoff. also when i am in first gear my vtec kicks at 6 and every gear after that is at 7rpm is this because i have a chipped ecu or just a fucked up one.
Modified by ek2k at 1:52 AM 2/23/2005
ek2k's Avatar
Default Re: quick question on P30 ecu (ek2k)
bump it
Old Feb 22, 2005 | 02:44 PM
mmuller's Avatar
Mad Scientist
open it and check if its chipped
Old Feb 22, 2005 | 02:46 PM
ek2k's Avatar
Default Re: quick question on P30 ecu (mmuller)
will i damaged it if i open it just take off screws and look for anything that says like skunk2, mugen, ect right?
Old Feb 22, 2005 | 02:55 PM
PrettyLude's Avatar
no you won't damage anything, and yes look for something that says skunk2 mugen etc
Old Feb 22, 2005 | 03:12 PM
ek2k's Avatar
Default Re: (PrettyLude)
thanks everyone
Old Feb 22, 2005 | 04:54 PM
ek2k's Avatar
Default Re: (ek2k)
bump...
Old Feb 22, 2005 | 06:29 PM
mmuller's Avatar
Mad Scientist
Default Re: (ek2k)
looks to me thats stock, unless the stock eprom was reprogrammed
Old Feb 22, 2005 | 07:31 PM
ek2k's Avatar
Default Re: (mmuller)
well i dont know to me it looked stock as well unless if indeed it was re programed because it cant be possible the that there is no rpm governor stock right?
Old Feb 23, 2005 | 10:09 AM
ek2k's Avatar
Default Re: (ek2k)
bump
Old Feb 23, 2005 | 02:31 PM
turbohondaboi's Avatar
its chipped. I can see it from the pic
Old Feb 23, 2005 | 07:06 PM
Jim Truett's Avatar
Default Re: (turbohondaboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohondaboi &raquo;</TD></TR><TR><TD CLASS="quote">its chipped. I can see it from the pic</TD></TR></TABLE>
Yeah, but do you know what you are looking at? I'm guessing no.
You have an ECU with an OEM installed external ROM. This chip contains OEM Honda programming, but being code #72 is unusual to me. I would expect it to be #203 in a JDM P30. What is the full part number on the side of the ECU?
I have typically seen the external ROM only on automatic P30 ECUs, though you do not have any of the high side switches for tranny control.
The MCU is blank in this particular ECU, so you must always run an external ROM. If you remove J1 on the backside of the PCB, the ECU will be stuck in limp mode.
Old Feb 24, 2005 | 06:10 AM
ek2k's Avatar
Default Re: (Jim Truett)
i will have the full part number on the side of the ecu this afternoon thanks you guys.
Old Feb 24, 2005 | 12:11 PM
dont you hate it when you lost your long a$$ post when it says your not logged in but you are. Well anyways Ill keep it short.
Jim is right it is an external rom, either factory or aftermarket.
It is definately not an auto cause I do know what I am looking at.
The rom with the copper colored sticker on it. does it look like it has been resoldered. only way to know for sure is to read the rom.
Old Feb 24, 2005 | 04:34 PM
ek2k's Avatar
this is how the ecu reads on the side
37820-p30-000
470-100604
denshigiken ASH
Old Feb 24, 2005 | 06:38 PM
ek2k's Avatar
Default Re: (ek2k)
Old Feb 25, 2005 | 07:54 AM
ek2k's Avatar
Default Re: (ek2k)
bump
bigplayj17
Apr 9, 2008 12:43 AM
xcon0570
Mar 1, 2008 07:54 AM
perseverance
Feb 20, 2007 08:45 AM
