HELP! car shaking under acceleration
Old Feb 22, 2005 | 10:31 AM
AGENT 99's Avatar
Default HELP! car shaking under acceleration
98 civic dx. Just got new axles in the front due to blown cv boots and had my mechanic install them. Damn car shakes under acceleration. What the hell is this?? I took it to a tire store and they cleaned all the old grease off the inner wheels so it wouldnt shake at highway speeds. Not sure if its worked yet as I havent gotten on the expressway yet with it. Still shakes like a **** off the line.
ANybody know what this could be??
Old Feb 22, 2005 | 10:34 AM
93civicsedan's Avatar
Default Re: HELP! car shaking under acceleration (6gcivic)
did you get an alignment after the axles where replaced?
Old Feb 22, 2005 | 10:38 AM
Happyman's Avatar
Tighten the lug nuts lol iono but that's what happened to me this weekend....I hand tightened them and then when I put the car down I forgot to hit them with the air gun....**** was shaking good. lol
Old Feb 22, 2005 | 11:48 AM
SOHC4life 96's Avatar
Default Re: HELP! car shaking under acceleration (Happyman)
So its only durning acceleration? Once you get to a cruising speed its fine? Sounds like a busted engine mount to me. But I'm not sure.
Old Feb 22, 2005 | 11:52 AM
medside's Avatar
Default Re: HELP! car shaking under acceleration (SOHC4life 96)
could be misbalanced tire, usually mine shakes about 60 mph if its not balanced right. also could be your transmission. my tranny was making my car shake bad also. or he give you a bad axyle
Old Feb 22, 2005 | 12:44 PM
Luserkid's Avatar
Default Re: HELP! car shaking under acceleration (medside)
Bald tires, slipping clutch, motor mounts?
Check for bald tires: Easy look at your tires, if there bald then there bald.
Check for slipping clutch: Put the car in first up to 4mph and then put it into 4th. If the clutch grabs and the car stalls its good, if it shakes like hell and keeps going then its slipping.
Check for bad motor mounts: Lift the car securly on jack stands. Have someone in the car and with the car on shifting through gears. If you see the motor shake alot then its a motor mount and look around to see which moves the most during this check.
Old Feb 22, 2005 | 12:51 PM
civicboisi's Avatar
Default Re: HELP! car shaking under acceleration (Luserkid)
also...if you can check the axle nut...make sure it's on tight...could've came loose or a lil bit loose...
make sure all ur tie rods and ball joints are secure
Old Mar 1, 2005 | 01:43 AM
AGENT 99's Avatar
Default Re: HELP! car shaking under acceleration (civicboisi)
Could it possibly be that bad rear motor mount I've been meaning to get fixed??
dem0nk1d
13
Nov 3, 2010 02:01 PM
nautica_t
Oct 25, 2006 06:28 PM
fackyou
Sep 11, 2006 07:14 PM
bigdgsr
Sep 1, 2006 11:53 AM
xlusiveracer
10
Jan 17, 2006 10:22 AM
