max BOOST for stock ITR
Old Feb 22, 2005 | 06:24 AM
boosted k20's Avatar
Default max BOOST for stock ITR
hey just wondering what is the max boost pressure u can run on a stock internal Type R? is 10 psi overkill if the car is being tuned by a standalone ems?
Old Feb 22, 2005 | 06:32 AM
Philly_NBP_R's Avatar
Default Re: max BOOST for stock ITR (boosted k20)
try the forced induction forum... and search!
Old Feb 22, 2005 | 06:46 AM
Default Re: max BOOST for stock ITR (Philly_NBP_R)
i did search! no results when i typed in integra type r boost.... and i posted in FI too.
Old Feb 22, 2005 | 06:50 AM
.RJ's Avatar
.RJ
Heh, depends on how long you want it to run before the crankcase ventilates itself
Old Feb 22, 2005 | 06:58 AM
Black R's Avatar
25 Year Member
9-12psi..... TUNED of course.
Old Feb 22, 2005 | 07:07 AM
Default Re: (Black R)
cool. i was only gonna run 10 psi max. but i was wondering since this is a high compression motor, i might run into problems. i'll just retard timing a little bit more for higher boost numbers
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">hey just wondering what is the max boost pressure u can run on a stock internal Type R? is 10 psi overkill if the car is being tuned by a standalone ems?</TD></TR></TABLE>
10 psi on what?
A T25? GT35R?
You can't gauge what a motor can take by boost levels, but by WHP.
Old Feb 22, 2005 | 07:08 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">9-12psi..... TUNED of course. </TD></TR></TABLE>
I'm surprised you gave an answer. Different turbos and other differences can change that answer a bit.
My reply would have been to ask for more info on what parts/etc he's using.
edit: err. I was beat to the reply.
Old Feb 22, 2005 | 07:10 AM
itr_dc2's Avatar
Default Re: (Dave-ROR)
Drag and most turbonetic as well as greddy kits recommend on an ITR no more than 8 pounds.
Old Feb 22, 2005 | 07:14 AM
Default Re: (itr_dc2)
i think the kid is using a drag kit or a revhard kit. not too sure
Old Feb 22, 2005 | 08:05 AM
white rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Drag and most turbonetic as well as greddy kits recommend on an ITR no more than 8 pounds.</TD></TR></TABLE>
I would have to agree.
Contact Dr. Pooface in here. He just got a turbo kit installed with stock internals.
Modified by white rocket at 11:43 AM 2/22/2005
Old Feb 22, 2005 | 08:20 AM
Finland's Avatar
That's definitely a loaded question because there are a huge number of factors that will determine how many hours, of years the motor will withstand boost.
I've been running 10 Psig boost with my setup for 3.5 years (about 35K miles). On the dyno my boost levels creeped to 11.5 Psig, I've since gone to a larger wastegate.
Old Feb 22, 2005 | 10:05 AM
fqnjdmboy's Avatar
Man I would personally think about boosting on stock block...its really not a good idea...but if you choose to go this route make sure the car is tuned properly....otherwise bye bye...factory p73 pistons!
Old Feb 22, 2005 | 10:39 AM
Dave-ROR's Avatar
Default Re: (fqnjdmboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fqnjdmboy &raquo;</TD></TR><TR><TD CLASS="quote">Man I would personally think about boosting on stock block...its really not a good idea...but if you choose to go this route make sure the car is tuned properly....otherwise bye bye...factory p73 pistons!</TD></TR></TABLE>
There is absolutely nothing wrong with boosting on a stock block. You just can't be an idiot when doing so.
Old Feb 22, 2005 | 11:35 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">
There is absolutely nothing wrong with boosting on a stock block. You just can't be an idiot when doing so.</TD></TR></TABLE>
what about NOS?
Old Feb 22, 2005 | 11:39 AM
Dave-ROR's Avatar
Default Re: (People_Mover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by People_Mover &raquo;</TD></TR><TR><TD CLASS="quote">
what about NOS? </TD></TR></TABLE>
Change your spark plugs often y0
Old Feb 22, 2005 | 12:05 PM
FOrSfEd's Avatar
There is nothing wrong with boosting a stock block if you know what you are doing. I run 7 psi daily and have been for about 2 years. It spikes at times to 10 but it's not bad. I run a t3/t67 turbo.
Old Feb 22, 2005 | 12:07 PM
clayton bigsby's Avatar
i had TODA spec C's and a home made nos kit with a 42 pill wich i think is a 100 shot and a chipped p28 and a vtec controler and my **** was unstopble all on a stock block with 40k
Old Feb 22, 2005 | 12:10 PM
hYpE-R-29's Avatar
Default Re: (allmotaitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotaitr &raquo;</TD></TR><TR><TD CLASS="quote">
i had TODA spec C's and a home made nos kit with a 42 pill wich i think is a 100 shot and a chipped p28 and a vtec controler and my **** was unstopble all on a stock block with 40k </TD></TR></TABLE>
HUHHHHHHHHH!!!!!!!
Old Feb 22, 2005 | 12:42 PM
Dave-ROR's Avatar
Default Re: (hYpE-R-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 &raquo;</TD></TR><TR><TD CLASS="quote">
HUHHHHHHHHH!!!!!!!</TD></TR></TABLE>
He has an ITR with Toda Spec C cams, a chipped P28 and a VAFC or some other VTEC controller with a home made/pieced together nitrous setup with a 100 shot pill on his stock block that has 40k on it total, or with the above mods (not sure which, the post wasn't clear on that part).
Modified by Dave-ROR at 5:11 PM 2/22/2005
Old Feb 22, 2005 | 01:06 PM
hYpE-R-29's Avatar
He has an ITR with Toda Spec C cames, a chipped P28 and a VAFC or some other VTEC controller with a home made/pieced together nitrous setup with a 100 shot pill on his stock block that has 40k on it total, or with the above mods (not sure which, the post wasn't clear on that part).</TD></TR></TABLE>
Ohhhh!!
Old Feb 22, 2005 | 10:43 PM
Chris F's Avatar
Default Re: max BOOST for stock ITR (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Heh, depends on how long you want it to run before the crankcase ventilates itself </TD></TR></TABLE>
I got to get me one of THOSE!
If you boost a stock internaled ITR, and you take it to HPDE's, plan on saving for a rebuild (I did!).
10 PSI with a Greddy kit isn't unreasonable, that's what I was running. Other higher efficiency setups will blow chunks at 8 PSI. YMMV. Stay under 300 WHP if you don't change any internals.
Of course, I probably blew ringlands at 10 PSI, ran it at the track a few more times at 8 PSI until #3 bit the dust. Now I get to build the motor and get more b00st! (Hooray!)
Old Feb 22, 2005 | 11:46 PM
uNF$@#!'s Avatar
problem with these kits isnt the 8 lbs or higher...its the creep that gets you.
Old Feb 23, 2005 | 01:08 AM
Haleiwa-Brando's Avatar
Default Re: (255.255.255.255)
Or crack your #4 Cylinder wall in half *cough cough. Or blow your head gasket *cough cough...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Drag and most turbonetic as well as greddy kits recommend on an ITR no more than 8 pounds.</TD></TR></TABLE> I would recommend getting a stainless steal header. The cast iron pieces will eventually crack and have a shorter life span in general.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">That's definitely a loaded question because there are a huge number of factors that will determine how many hours, of years the motor will withstand boost.</TD></TR></TABLE>
How about three days with a horrible 12-14lb boost spike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">
problem with these kits isnt the 8 lbs or higher...its the creep that gets you. </TD></TR></TABLE>
I agree. Though once you get it all dialed in and you don't have very much creep...I wouldn't boost more than 8lbs max to be on the safe side while running a stock bottom end. I am now learning the hard way and it's costing me thousands. **** happens I guess.
If you have the time and money...do all the internal work first. You will be much happier with yourself.
Aloha,
Brandon
Old Feb 23, 2005 | 12:08 PM
Default Re: (Haleiwa-Brando)
thanks alot guys. i appreciate all the info. right now we're just gonna tune the type r on a conservative 5 psi (car doesnt have a boost controller to up the psi. car's run n on a 5 lb spring)once he gets the boost controller we'll only raise boost to 8 psi max
