Jdm d15b and two questions
Old Feb 22, 2005 | 02:30 AM
spoonef's Avatar
Default Jdm d15b and two questions
My idle will sometimes be constant(1000)and sometimes it will act up and go down to 500 after driving and then back up to 1000 after some driving.I was thinking maybe just clean out the idle control valve and bleed my coolant system and see if that helps.If i decide to get another icav(brand new)which one will work? d15z1 or d16z6.
Also i have a depo foglight kit and when i turn it on my idle drops a bit and its very annoying.Now i understand that things like this will take power but is there anyway to reduce it from taking so much power? or is this all leading up to the faulty icav.
Old Feb 22, 2005 | 10:28 AM
spoonef's Avatar
Default Re: Jdm d15b and two questions (spoonef)
bump
Old Feb 22, 2005 | 10:42 AM
dantastic's Avatar
if the altenator has a heavy load, it sends a signal to the ecu to bump up the idle. it sounds like you may have a bad iacv. most obd1 iacv's are the same, so you might want to try the one off your old motor. i have an extra one around here somewhere....
Old Feb 22, 2005 | 10:44 AM
POE's Avatar
POE
https://honda-tech.com/zerothread?id=699787
try that thread and read it, i had an idel problem i could never figure out, i have replaced 3 iacv's bleed the coolant, check vacuum lines, and it ended up being the FITV
hope this helps.
b20bFourDoorCivicLX
Honda CR-V & Element
Apr 21, 2013 07:21 AM
hondachris1994
Mar 3, 2006 06:49 AM
martingouda
Nov 24, 2005 11:54 AM
jam05pr
Oct 29, 2005 01:15 PM
Firefoxracer
Jun 16, 2005 08:04 AM
