adjusting the tps
Old Feb 22, 2005 | 12:19 AM
ty1585's Avatar
Default adjusting the tps
Ok i went to adjust my TPS to get it at .45 at closed throttle but the lowest i can get the voltage down to is .73. The tps is turned all the way that direction and won't go any farther. If anyone has any suggestions lmk. I don't know if the spring in the sensor is bad or what. Oh yeah if it helps its b18c1 with a SKunk2 TB.
Old Feb 22, 2005 | 08:12 AM
civic-4-ges's Avatar
Default Re: adjusting the tps (ty1585)
What is making you adjust the TPS to begin with? (not trying to be an ***)
What is the max voltage you can get out of it?
Old Feb 22, 2005 | 08:56 AM
ty1585's Avatar
Default Re: adjusting the tps (civic-4-ges)
i put on a skunk2 TB
Old Feb 22, 2005 | 10:08 PM
ty1585's Avatar
at closed throttle the max voltage will go well over 1V
Old Feb 23, 2005 | 06:43 AM
DaX's Avatar
DaX
Loved
Community Favorite
Ideally, you should have about 0.45V @ closed throttle and 4.5V @ WOT. Mine adjusted down fine. Are you sure you're taking the voltage on the correct wires?
Old Feb 23, 2005 | 08:04 AM
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Ideally, you should have about 0.45V @ closed throttle and 4.5V @ WOT. Mine adjusted down fine. Are you sure you're taking the voltage on the correct wires?</TD></TR></TABLE>
This is what im wondering, it just does not seem right
Old Feb 23, 2005 | 05:58 PM
ty1585's Avatar
Default Re: (civic-4-ges)
Yeah it doesn't seem right, thats why i was seeing if anyone have any suggestions, the problem is i can't get the voltage down to .45 the tps is turned to the max and will only get to .73. I am testing the middle wire which i am almost positive is the right one.
Old Mar 7, 2005 | 08:12 AM
b18bEG's Avatar
the right wirer is the red/blue wire, yes it is in teh middle
Old Mar 26, 2005 | 03:04 AM
137's Avatar
137
Default Re: (DaX)
supposed to be 5.v closed and 4.5 open.
Old Mar 27, 2005 | 08:39 AM
Phasehonda's Avatar
Default Re: (ty1585)
Since everything is unplugged is there any chance you might made a mistake on the connections between the TPS and MAP? The reading seems to be like from a typical MAP sensor connector instead of the TPS.
Old Mar 28, 2005 | 01:19 PM
amadriga's Avatar
Some TPS needs to remove the metallic ring on the screw holes, so you can move the TPS a little more.
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
saviour250
Mar 14, 2009 03:42 PM
TwoKSiR
Mar 25, 2008 11:11 AM
TheSav
Apr 10, 2006 11:23 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
