Burnout= Worn clutch??
Old Feb 21, 2005 | 11:22 PM
SIcivicHATCH's Avatar
Default Burnout= Worn clutch??
Ok I have a clutchmaster Stage 3 Clutch in my civic and two days ago I did a nice burn out and now my clutch is grabbing right at the end like it is going out. The bitch only has 3000 miles on it. Any ideas?
Old Feb 21, 2005 | 11:27 PM
jeef84's Avatar
Default Re: Burnout= Worn clutch?? (H22siCivic)
Stg3? Idk man, are you running a stock or aftermarket flywheel?
Old Feb 21, 2005 | 11:35 PM
JDMlyfestyle's Avatar
did you properly break in the clutch?
Old Feb 22, 2005 | 03:55 AM
94_HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22siCivic &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have a clutchmaster Stage 3 Clutch in my civic and two days ago I did a nice burn out and now my clutch is grabbing right at the end like it is going out. The bitch only has 3000 miles on it. Any ideas?</TD></TR></TABLE>
are you sure your tires were smoking and not your clutch? Doesn't normally happen unless you don't break in the clutch correctly, but it does happen. Heard a story a while back about this happening to a twin disk clutch.
Old Feb 22, 2005 | 06:46 AM
cnyej1's Avatar
Default Re: Burnout= Worn clutch?? (94_HATCH)
*Nelson Voice* Ha Ha.
But in all seriousness, if you didnt break it in properly you can really fk it if your not careful.
Old Feb 22, 2005 | 11:30 AM
Default Re: Burnout= Worn clutch?? (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">did you properly break in the clutch?</TD></TR></TABLE>
Clutch was not slammed or raced at all for 2500 miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeef84 &raquo;</TD></TR><TR><TD CLASS="quote">Stg3? Idk man, are you running a stock or aftermarket flywheel?</TD></TR></TABLE>
Clutchmaster flywheel also *** i am just going to get a act stage 2 Ive always hated clutchmaster anyway. I got the clutch for like $100 brand new
Old Feb 22, 2005 | 11:42 AM
Luserkid's Avatar
Try bleeding the clutch maybe that will help ::shrugs::
Old Feb 22, 2005 | 11:46 AM
Default Re: Burnout= Worn clutch?? (Luserkid)
ok ill try that thanks alot for the help guys anyother help is appreciated also.
Old Feb 22, 2005 | 12:03 PM
sohcvtec1995's Avatar
Dnt do burnouts. But was the clutch installed properly?Flywheel resurfaced?
And you are positive that you were doing a burnout and not a clutch out?
Old Feb 22, 2005 | 12:08 PM
biotech0123's Avatar
Default Re: Burnout= Worn clutch?? (sohcvtec1995)
that sort of scares the hell out of me because I just bought a stg3 with a fly
Old Feb 22, 2005 | 12:11 PM
POE's Avatar
POE
Default Re: Burnout= Worn clutch?? (biotech0123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biotech0123 &raquo;</TD></TR><TR><TD CLASS="quote">that sort of scares the hell out of me because I just bought a stg3 with a fly</TD></TR></TABLE>
dont be scared, this dude just messed up his clutch, its not the clutch quaultity.
Old Feb 22, 2005 | 12:22 PM
I was definately doing a burnout. The flywheel and clutch kinda made some noices like they were grinding against eachother. And for the past couple of weeks the clutch has been ground a little bit considering second gear syncro going bad.
Old Feb 23, 2005 | 01:23 AM
94_HATCH's Avatar
buy an rps clutch from me
Old Feb 23, 2005 | 02:37 AM
92civicb18b1's Avatar
ok...the clutch does rub against the flywheel, it's actually mounted to it. That is how the transmission is engaged and disengaged.
I think your clutch is just fucked.
Old Feb 23, 2005 | 02:45 AM
oldskoolcivic94's Avatar
how do you break in a clutch? no high revving for the first 3k?
Old Feb 23, 2005 | 04:06 PM
Default Re: (oldskoolcivic94)
drive it "normal" for the first 500 miles.
ic89
Oct 16, 2006 05:22 PM
DC494LS
Oct 8, 2005 01:58 AM
JDM_EH2
Sep 10, 2005 11:34 PM
dohcdelsol
14
Aug 16, 2004 10:42 AM
ALF
Nov 30, 2001 09:58 PM
