Oil feed line length GSR
Old Feb 21, 2005 | 11:03 PM
b18-c-rx's Avatar
Default Oil feed line length GSR
On my b18c, how long should my braided oil line from the back of the block (pressure sensor) to the turbo be?
any suggestions on where to buy it from?
Old Feb 21, 2005 | 11:06 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Oil feed line length GSR (b18-c-rx)
it really depends how you wanna route your oil feed line. but 5 feet should be more then enough. you can find them on http://www.summitracing.com
Old Feb 21, 2005 | 11:07 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx &raquo;</TD></TR><TR><TD CLASS="quote">On my b18c, how long should my braided oil line from the back of the block (pressure sensor) to the turbo be?
any suggestions on where to buy it from?</TD></TR></TABLE>
I sell them or http://www.fast-turbo.com Stan is my supplier, quality kits and Stan knows his fittings and line sizes and all that info!!!! Also best pricing around from me and Stan on these since we sell large volumes of these!!!
Old Feb 21, 2005 | 11:08 PM
b18-c-rx's Avatar
Default Re: Oil feed line length GSR (AzntaggeR)
is it legitimate to route my oil line just around the block and into the turbo? will that be enough angle to get the oil into the turbo?
if i wanted to do that, would 5 be reasonable? I dont want random oil lines hanging out like flab.
Old Feb 21, 2005 | 11:10 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx &raquo;</TD></TR><TR><TD CLASS="quote">is it legitimate to route my oil line just around the block and into the turbo? will that be enough angle to get the oil into the turbo?
if i wanted to do that, would 5 be reasonable? I dont want random oil lines hanging out like flab.</TD></TR></TABLE>
I like to use a Golden Eagle oil filter sandwich adapter with one of Fast-turbo.com's oil feed lines! Great set up, I like to route it towards the passenger side
b18-c-rx's Avatar
fast-turbo.com is down, or something. The buy stuff doesnt work. I want to buy asap, now preferably. I just spent the last like 1 hr figuring out all the fittings so i have that down. all i need now is the length for my oil line - if you can sell a good one to me now, that'd be cool.
Old Feb 21, 2005 | 11:13 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx &raquo;</TD></TR><TR><TD CLASS="quote">fast-turbo.com is down, or something. The buy stuff doesnt work. I want to buy asap, now preferably. I just spent the last like 1 hr figuring out all the fittings so i have that down. all i need now is the length for my oil line - if you can sell a good one to me now, that'd be cool.
PM sent sir.
Old Feb 21, 2005 | 11:23 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx &raquo;</TD></TR><TR><TD CLASS="quote">fast-turbo.com is down, or something. The buy stuff doesnt work. I want to buy asap, now preferably. I just spent the last like 1 hr figuring out all the fittings so i have that down. all i need now is the length for my oil line - if you can sell a good one to me now, that'd be cool.</TD></TR></TABLE>
Check out his thread here on H-T:
https://honda-tech.com/zerothread?id=1011921
You can just paypal him the required amount to his paypal addy stan@fast-turbo.com
I got my drain line from him, and for $2 he even gave me a cap that I can screw onto my oil pan fitting so that I can still use the same oilpan when I remove the drain line.
Old Feb 22, 2005 | 12:07 AM
Boostfed's Avatar
New User
Default Re: Oil feed line length GSR (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
I got my drain line from him, and for $2 he even gave me a cap that I can screw onto my oil pan fitting so that I can still use the same oilpan when I remove the drain line.</TD></TR></TABLE>
Just FYI I am a Fast-Turbo dealer and work very closely with Stan on his own products and may others! Oil feed/return sold to customer above. Early bird catches the worm.
ÁrniMkv
Feb 10, 2012 07:02 AM
94EGZI
Oct 30, 2008 10:42 PM
B18 CYA
Apr 21, 2004 04:34 PM
JrCRXHF
Aug 5, 2003 08:29 AM
SuzukaBlueAP2
Jul 7, 2003 02:36 PM
