rear 99 LS Teg rear sway bar on an EK?
Old Feb 21, 2005 | 10:29 PM
specificcivic's Avatar
Default rear 99 LS Teg rear sway bar on an EK?
will a 99 LS Teg rear sway bar fit a 96 civic cx hb w/ a 99 ls rear disc brake conversion?
Old Feb 22, 2005 | 11:55 AM
bump to the top...PLS I really need help.
Old Feb 22, 2005 | 12:12 PM
boostsohfast's Avatar
Default Re: (specificcivic)
look at the lower control arms and see if they have holes for the sway bar
Old Feb 22, 2005 | 12:15 PM
Dacalac's Avatar
Default Re: (boostsohfast)
if you're using your CX LCA's then no it won't work. You would need to need some new LCA's that come with the sway bar holes. Civic Ex/Si LCA's would work as well as any LCA from an integra.
ek4d00r's Avatar
you need the endlinks from the 99-00 civic si
redyute
Oct 3, 2012 03:25 PM
civexspeedy
Aug 25, 2006 02:43 PM
DC2#309
Apr 5, 2005 07:54 PM
ill phil
Jul 25, 2003 05:23 PM
Amuse9
Dec 30, 2002 12:48 PM
