2.0L LS/VTEC
Old Feb 21, 2005 | 10:04 PM
Novtecdohc's Avatar
Default 2.0L LS/VTEC
Modified by Novtecdohc at 5:54 PM 2/22/2005
Old Feb 22, 2005 | 02:19 AM
AllmotaB18EH2's Avatar
Default Re: 2.0L LS/VTEC (Novtecdohc)
Old Feb 22, 2005 | 02:27 AM
H.A.R.T B18C1EG6's Avatar
Default Re: 2.0L LS/VTEC (H.A.R.T B18C5EH2)
good luck mang
Old Feb 22, 2005 | 07:26 AM
NEXTAMERICANIDOL's Avatar
My swap is Finally Finshed...
2.0L LS/VTEC
B18a Block bored
B16a2 Head
OBD0 B16a Distribtor
OBD0 B18a Intejector w/Resister Box
OBD0 B16a ECU
Oversized P30 B16a Pistons
Stock LS Rods
GSR Oil Pump
GSR Water Pump
GSR Timing Belt
GSR Head Bolts
Apexi VAFC
92-93 GSR Tranny
92-93 CLutch
4-1 Type R Header
Apexi N1 Muffler......
So what do you guy think of my new setup?
I made 192HP and 136flbs On the dyno.....
I'm pretty sure that your engine is not a 2.0L.
Looks good though! What cams are you running and what kind of dyno
did you do your runs on?
Phatch99's Avatar
Default Re: 2.0L LS/VTEC (H.A.R.T B18C1EG6)
looks good... keep us updated on some track times...
Old Feb 22, 2005 | 07:32 AM
clint g's Avatar
Default Re: 2.0L LS/VTEC (Phatch99)
Good numbers
Old Feb 22, 2005 | 03:30 PM
hybridpatient95's Avatar
you cant oversize b16 pistons to be that big.. def not a 2.0L
Old Feb 22, 2005 | 03:34 PM
Combustion Contraption's Avatar
how did you get 2.0 with OS ctr's? what cams?
Old Feb 22, 2005 | 03:45 PM
Novtecdohc's Avatar
Default Re: (LsVtec92Hatch)
sorry, I didnt ment P30, I always get those confused with ITR Pistons... My bad... Right now im running a ITR Intake Cam and a GSR Exhaust cam.... Retarted 2degrese/
Old Feb 22, 2005 | 04:51 PM
Almtrhb's Avatar
So how did you get a 2.0L if you didnt go 84mm or bigger you dont have a 2.0L. The only other way to get a 2L is by stroke and that would require a 95mm crank. Is the head ported?
Old Feb 22, 2005 | 05:14 PM
Big Teggie's Avatar
Default Re: (Almtrhb)
What happened to the original post?
Old Feb 22, 2005 | 05:41 PM
1Quikgsr's Avatar
Default Re: (LSVTEC_DC2R)
Old Feb 22, 2005 | 06:27 PM
hahahaha, that was awesome...
Old Feb 25, 2005 | 07:17 PM
SIinDisguise's Avatar
I have a 99 si coupe. here are my mods. I havent dynod it yet the motor is bein put together right now. I was just wonderin if anyone has an idea of what I'll be putting out.
Engine Mods: (B20Vtec) Built 98 CRV Block, 99 SI Transmission, 99 SI ported & polished head, Crane Stage 2 Cam Shafts, Super Tech valves, Super Tech Dual Titanium valve springs, Super Tech Titanium retainers, AEM Tru Time Adjustable Cam Gears, Apexi Vtec Controller, AEM Short ram intake, 70mm Throttle body, Skunk 2 Intake Manifold, NGK Spark Plug Wires, Zex Plugs, AEM Fuel pressure Regulator, JE Stroker Kit ( JE 11:1 Compression Pistons, Eagle Rods, Eagle Forge Steel Crank),Golden Eagle Oil Line Kit, Jegs Fuel Pressure Gauge, ACT Street Light 12lbs Flywheel, ACT Stage 2 Xtreme Pressure Plate Clutch, DC Sport 4-1 Headers, Hi-Flow Cat,Greddy Evo Exhuast System, Pro 1 Short Shifter, Enjo Urethane Motor Mounts
Old Feb 25, 2005 | 07:20 PM
Default Re: 2.0L LS/VTEC (NEXTAMERICANIDOL)
Old Feb 25, 2005 | 07:31 PM
hitvtecgetloud09's Avatar
Default Re: 2.0L LS/VTEC (SI_In_Disguise)
^ why did u post it twice...oh i just noticed the join date.. ''05 nvm
Old Feb 26, 2005 | 05:20 AM
swaytec360's Avatar
someone from the 614 building a stroked b20b should be interesting kinda low cr though whose doing you machine work (pr) what stroke are you doing
WinniPeg 89 Ef
15
Apr 12, 2012 11:21 PM
thedb63
Dec 25, 2009 09:42 AM
Panda Eg6
Northwest (Sales)
26
Sep 10, 2008 06:33 PM
Novtecdohc
Apr 13, 2005 04:50 AM
teg92
Dec 9, 2001 11:24 AM
