dont know wat to believe anymore about hi flow cats passing smog and performance?
Old Feb 21, 2005 | 04:43 PM
egg_baLLa's Avatar
Default dont know wat to believe anymore about hi flow cats passing smog and performance?
i've been searching and reading around about this topic and i've been getting mixed responses about hi flow cats on whether it will pass smog here in california.
i just installed an obd2 carsound hi flow cat and wanted to find a definitive answer on whether it will pass or not? (btw i have and obd2 cat that was originially meant for some ford v8.)
and also will it hinder or raise performace, all be it even if it is just a miniscule/big loss/gain in power/torque? is obd2 that much different than obd1 in respect to power/torque and passing/failing smog?
thanks guys.
Old Feb 21, 2005 | 06:32 PM
egg_baLLa's Avatar
Default Re: dont know wat to believe anymore about hi flow cats passing smog and performance? (egg_baLLa)
any insight?
Old Feb 21, 2005 | 08:12 PM
egg_baLLa's Avatar
Old Feb 21, 2005 | 09:07 PM
confucius's Avatar
i have a 2.75 catback with DC 4-1 header.
passed with no problem.
the only time it failed was when i thought i could beat the system by taking the check engine light out.
now i have to pay 135 to get a new purge control solenoid and charco cannister.
code 191
Old Feb 21, 2005 | 11:00 PM
egg_baLLa's Avatar
Default Re: dont know wat to believe anymore about hi flow cats passing smog and performance? (confucius)
were u running a hi flow cat tho?
Old Feb 21, 2005 | 11:22 PM
confucius's Avatar
it was hollowed out.
Old Feb 22, 2005 | 12:32 AM
egg_baLLa's Avatar
does anybody else have any opinions about my questions?
Old Feb 22, 2005 | 10:22 AM
dawalude's Avatar
as long as it has a carb number, it will pass. thats the point of having that carb eo number, is the fact that the company has proven it will pass so you dont have to worry about it. reasons why others dont pass b/c they have a hi flow cat is b/c they have other mods causing them not to pass, not b/c of their carb legal hi flow cat (unless it was defective). you will pass, given that there arent any other factors that effects your smog, such as bad o2, non-carb legal mods, etc.
Old Feb 22, 2005 | 10:35 AM
sir boostalot's Avatar
Default Re: dont know wat to believe anymore about hi flow cats passing smog and performance? (dawalude)
when i had my civic i had a manaflow exhaust with cat - 2.5i nch piping and no resonator and i didn't have any problems passing smog.
Old Feb 22, 2005 | 10:42 AM
dawalude's Avatar
Default Re: dont know wat to believe anymore about hi flow cats passing smog and performance? (sir boostalot
fyi exhaust diameter doesnt effect smog readings, only decibal readings. you could have a 3.0" piping exhaust and still pass smog given your car doesnt have any other non-carb mods or problems
Old Feb 22, 2005 | 11:00 AM
egg_baLLa's Avatar
thanks for the responses so far guys.
Old Feb 23, 2005 | 03:36 AM
egg_baLLa's Avatar
i also have another question:
since i have an obd2 engine in my obd1 civic, does it matter which cat i use (obd1 or obd2)?
Old Feb 23, 2005 | 05:19 AM
sleeper96's Avatar
I have a random tech hi flow cat on my car and pass smog with no problems.Since you have a obd1 computor in your car it doesn't matter what cat you use because your obd1 ecu only uses one o2.
Old Feb 23, 2005 | 06:50 AM
gsr_to_the_MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucius &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2.75 catback with DC 4-1 header.
code 191</TD></TR></TABLE>
u talking bout the light in the back of the cluster? what does taking out the check engine light have to do with it? jsut wondering? i didnt pass with i/h/cat/e until i put the stock header and exhaust back on but i was close to passing thou
Old Feb 23, 2005 | 03:24 PM
egg_baLLa's Avatar
Default Re: dont know wat to believe anymore about hi flow cats passing smog and performance? (gsr_to_the_MA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper96 &raquo;</TD></TR><TR><TD CLASS="quote">I have a random tech hi flow cat on my car and pass smog with no problems.Since you have a obd1 computor in your car it doesn't matter what cat you use because your obd1 ecu only uses one o2.</TD></TR></TABLE>
alright, now that we got that out of the way, is one better than the other in terms of performance?
YoungMoneySi
May 25, 2008 06:00 PM
NorcalHB94
Jun 23, 2005 09:42 AM
Monochild
May 21, 2005 07:41 PM
xhatchracerx
Nov 10, 2004 07:18 AM
raskall
Feb 20, 2004 10:46 PM
