could any damage occur?
Old Feb 21, 2005 | 11:18 AM
budget's Avatar
Default could any damage occur?
well i was changing out a buddy's distributor and he thought i was done and attempted to start the car with no distributor on, obviously it didnt start but could any damgae occured to the car/motor?
Old Feb 21, 2005 | 11:31 AM
chrisgags13's Avatar
Default Re: could any damage occur? (ratboy)
no damage will occur. the engine has no spark and cant even run. the only damage you could do is if you crank it constantly and alot the starter and battery will wear extra. also no oil starvation would be a problem, but if you are only cranking it a few times...no big deal..actually a trick for when you install a new engine is pulling the coil wire and cranking the engine to help pre-lube the engine it before its initial startup.
Old Feb 21, 2005 | 02:19 PM
hoehouseworker's Avatar
Default Re: could any damage occur? (chrisgags13)
His engine should be fine. Just don't do it again for ***** and giggles.
Old Feb 21, 2005 | 03:41 PM
clemsoncb7's Avatar
Default Re: could any damage occur? (hoehouseworker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoehouseworker &raquo;</TD></TR><TR><TD CLASS="quote">His engine should be fine. Just don't do it again for ***** and giggles.</TD></TR></TABLE>
Wurd, it won't do any harm because its just not sending any spark. Just don't do it again
acuraTboo
Honda Civic (2006 - 2015)
Apr 24, 2013 04:16 AM
cvcntn
Apr 20, 2012 07:25 PM
vincsk2003
Feb 21, 2008 07:53 AM
valve79
Jan 14, 2005 06:05 AM
halim
Jun 9, 2002 07:50 PM
