Another B20 Swap Question
Old Feb 21, 2005 | 10:49 AM
91DroppedHatch's Avatar
Default Another B20 Swap Question
Heres my question, I plan on getting a CRX and dropping in a B20b. The only thing is I want everything converted to OBD-1, how would I do this? Is it just the injectors, dizzy, and ECU that need to be changed to an OBD-1. So all I would need is and OBD-1 LS, ecu, dizzy, and injectors on the B20 and it will run fine? I just wanted to ask and see if what I was thinking is right.
Modified by 91DroppedHatch at 2:28 PM 2/28/2005
Old Feb 28, 2005 | 01:27 PM
Default Re: Another B20 Swap Question (91DroppedHatch)
anyone?
Old Feb 28, 2005 | 05:28 PM
VTECVillain's Avatar
You will also need an OBD0 to OBD1 ECU adapter harness so that the OBD1 ECU will plug in. It will require some additional wiring (convert to 4 wire O2, a few plug changes, etc.) and depending on the model (if it's not an Si or HF) then you will need to also convert to MPFI using the stock DPFI harness.
woodenchef
Dec 25, 2012 01:17 PM
zapzach
19
Feb 24, 2012 10:35 AM
adeline
10
Mar 19, 2005 01:40 AM
1SIKCRX
Mar 27, 2004 04:43 PM
r7
Mar 14, 2003 10:08 AM
