Crazy Gains....crazy....???
Old Feb 21, 2005 | 10:48 AM
SiRLudeVtec's Avatar
Default Crazy Gains....crazy....???
OK...here's planned setup....I've heard so many different guess on my "projected" hp w/ psi ratings...can i get an EDUCATED guess or is that asking too much. I plan on having everything by the end of summer--maybe run into fall. Joe Demaree is going to do the install.
Turbonetics T3/t403 setup
Spearco Intercooler
RC 550cc injectors
Aem Fuel Rail, pressure regulator
Skunk2 Intake manifold
Skunk2 Stage II Camshafts and camgears
Skunk2 Valve springs and retainers
Larger throttle body
Sleeved block
Eagle Rods also
JE 9.5:1 Pistons, rings
Titanium Valves
NO HEAD WORK
Oh i also have a GReddy EVO Exhaust
Old Feb 21, 2005 | 10:49 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Crazy Gains....crazy....??? (AJBurks)
Really...it is too much to ask.
Old Feb 21, 2005 | 11:00 AM
Tinker219's Avatar
Default Re: Crazy Gains....crazy....??? (DaX)
Hrmm...especially when you omit the motor being used.
Old Feb 21, 2005 | 11:01 AM
john d
Guest
Posts: n/a
Default Re: Crazy Gains....crazy....??? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Hrmm...especially when you omit the motor being used.</TD></TR></TABLE>
lol
Old Feb 21, 2005 | 11:16 AM
tokesGTR's Avatar
Not to mention the size of the turbo, how much boost, what EMS, or what gas he's using.
A+
Old Feb 21, 2005 | 12:00 PM
-iLLuZioN-B18C1's Avatar
Default Re: Crazy Gains....crazy....??? (tokes1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokes1320 &raquo;</TD></TR><TR><TD CLASS="quote">Not to mention the size of the turbo, how much boost, what EMS, or what gas he's using.
A+</TD></TR></TABLE>
those would be important
Old Feb 21, 2005 | 12:02 PM
illi Adik's Avatar
Default Re: Crazy Gains....crazy....??? (-iLLuZioN-B18C1)
Ditch the cams too.
Old Feb 21, 2005 | 12:06 PM
Devine's Avatar
Default Re: Crazy Gains....crazy....??? (Jackson4Door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson4Door &raquo;</TD></TR><TR><TD CLASS="quote">Ditch the cams too.
id keep the cams but in order to make power on them hes going to need a larger turbo so there is less back pressure.
ditch the exhaust, if you want to make more power at xx psi level and have better spool up, run a 3 inch, its well worth it.
if i had to guess id say your gonna end up anywhere from 300-500 whp at 20psi
Old Feb 21, 2005 | 12:20 PM
philipwight's Avatar
Default Re: Crazy Gains....crazy....??? (Devine)
well with 550cc injectors you are limited to close to 350whp on most 4 cylinder hondas.
Old Feb 21, 2005 | 12:50 PM
m R g S r's Avatar
Default Re: Crazy Gains....crazy....??? (philipwight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight &raquo;</TD></TR><TR><TD CLASS="quote">well with 550cc injectors you are limited to close to 350whp on most 4 cylinder hondas.
Ehh. . . Someone (from HMT) made like 32x whp on dsm 450's. . . not recommended, but do-able, so I say a little more. . . .
MYEMWON
Mar 22, 2016 10:54 AM
h22nate
Apr 21, 2010 08:44 AM
Gatweb
Nov 5, 2004 10:09 AM
juicedh22
Feb 11, 2004 12:04 AM
redcivicek
Sep 29, 2003 02:37 PM
