a little help with spiral locks for pistons and file fitting rings?
Old Feb 21, 2005 | 09:39 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default a little help with spiral locks for pistons and file fitting rings?
I got floating wrist pins with spiral locks but I thought the locks would be the kind you can clip into place with needle pliers. They look like some sort of layered lock that I cant figure out. how do these things go in place??
also, what is the procedure for file fitting piston rings, yes, thats the kind I got...I didn't order them but that's what they gave me (for free so I'm going to use them).
I've got feeler gauges but dont know what type of file to use??
I assume you just push them down into the bore with a piston to get true flatness and measure and file until they fit right??
Old Feb 21, 2005 | 09:52 AM
beepy's Avatar
Default Re: a little help with spiral locks for pistons and file fitting rings? (stackz)
They are called spirolocks. They are a bitch to install, but with patience, they will never fail you.
Here is a good article:
http://www.beckracing.com/page10.htm
You can use a regular flat file to file the rings. Basically you install them square and 1/2" down the bore, check the gap, remove them, file them, reinstall, repeat.
Old Feb 21, 2005 | 09:53 AM
NJIN BUILDR's Avatar
Here's a little help with the spiroloxs. http://www.jepistons.com/pdf/2002-srp-full.pdf .They make tools to "file" fit rings.But you can do it with a flat file.Sounds like a "how to hotrod..." book will help you a lot.Even one covering american v-8's engines will help with all the basics.
Glenn
Old Feb 21, 2005 | 09:57 AM
stackz's Avatar
Community Builder
Default Re: a little help with spiral locks for pistons and file fitting rings? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">They are called spirolocks. They are a bitch to install, but with patience, they will never fail you.
yay me, looks like fun. I can see myself slipping while installing them now and gouging my finger on the end of one of these things
Old Feb 21, 2005 | 01:48 PM
speedworks's Avatar
they are hard to get in, but they will stay when youget them in there
integ401
Apr 22, 2007 04:31 PM
gaydm.accord
Mar 14, 2007 10:26 AM
DC4 Rasta
Jan 5, 2007 06:44 PM
LSVtechnologytur...
Feb 22, 2005 05:41 AM
yusoslo
Feb 9, 2004 03:13 PM
