type r cluster 240 kh/m
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civiceg6 »</TD></TR><TR><TD CLASS="quote">does anyone know where to find this cluster
http://www.showkurve.de/Movie/Integra3.mpg</TD></TR></TABLE>
It is a Euro-spec ITR cluster. They're not very common, so your best bet (if you really wanted one) would be to contact one of the members in the ITR forum who live in Europe and often source Euro-spec parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC Visions »</TD></TR><TR><TD CLASS="quote">It also looks like the JDM-spec ITR cluster which can be found as passwordjdm</TD></TR></TABLE>
Although the JDM cluster does have yellow needles like the Euro cluster in the video, the speedometer is quite different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">I got mine from Austrian Type-R.
feels like iam going hella fast
</TD></TR></TABLE>feels like iam going hella fast
hehe... you guys finally discovered this huh?
here's pics of mine:
If you really want it PM me with you offer, BTW, I bought this (wasnt cheap!) and never used it, the mileage is the same as in the pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaskedDC4 »</TD></TR><TR><TD CLASS="quote">^ whats wrong with 9000rpm? still making power y0
Not making a whole lot of power though (assuming stock cams), and it peaked quite a bit before that.
</TD></TR></TABLE>Not making a whole lot of power though (assuming stock cams), and it peaked quite a bit before that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSGSRT »</TD></TR><TR><TD CLASS="quote">I still have my stock LS cluster, only reason I like the Type-R cluster is because it lights up amber. But is it possible to just change the bulbs? </TD></TR></TABLE>
You can change the bulbs but it still wont be the same. The gauges themselves are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkTeg94 »</TD></TR><TR><TD CLASS="quote">If you buy a JDM ITR cluster, is there any problems in hooking it up to our USDM models?</TD></TR></TABLE>
Just depends what year your car is and what year the cluster is from. (94-97 integra should use 96 spec, 98+ should use 98 spec)
Usually the problems consist of gas gauge not working and such, but easy fix is done by just swapping the green film from the 2 clusters. Thats what I did for mine and it works perfectly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku »</TD></TR><TR><TD CLASS="quote">I had one but mine only went up to 190 kph. why is that? IF you really want I can post pictures.</TD></TR></TABLE>
The cluster you have is the JDM cluster, not the Euro-spec cluster.
yea, 3 amber 194 bulbs will help. and i paint my needle yellow, so i have a "jdm ls cluster"
