GT2871R Compressor Upgrade
Old Feb 20, 2005 | 09:52 PM
Tchleung's Avatar
Default GT2871R Compressor Upgrade
I'm looking at a GT2871R and I notice you can get the 4" inlet or the 2.75" inlet upgrade. Will the upgrade cause anymore lag then on the standard inelt size of 2" I think? Lotsa info on the GT28RS, not much on GT2871R and it's compressor upgrades. just curiosu how much more lag with the larger compressor hosung, and if top end will be effected enough to makeup for the slower spool
Modified by Tchleung at 6:23 PM 2/21/2005
Old Feb 21, 2005 | 05:23 PM
Tchleung's Avatar
TTT
Old Aug 24, 2006 | 01:53 AM
LeGeND4LiFe's Avatar
Default Re: (Tchleung)
Old thread, never answered. I would like to know the answer to this question please. Thanks!
Old Aug 24, 2006 | 07:12 AM
JDogg's Avatar
Default Re: (LeGeND4LiFe)
the 2871 is so laggy (compared to 28rs) anyway... it wont matter. that turbo is going to be limited more by the turbine housing/wheel than the compressor, so just keep with the 28rs.
Old Aug 24, 2006 | 07:27 AM
Tchleung's Avatar
HOLY old thread, I've been running the GT30R for a lnog time now instead haha
Old Aug 24, 2006 | 07:49 AM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">HOLY old thread, I've been running the GT30R for a lnog time now instead haha</TD></TR></TABLE>
haha, yeah i just noticed that... gt30 is a good turbo tho
Old Aug 24, 2006 | 10:17 PM
Default Re: (JDogg)
Threads about this always seem to go off topic. Does anyone actually know the performance differences between the different compressor housing options on the 2871r?
Old Aug 24, 2006 | 10:44 PM
Drew Peacock's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">the 2871 is so laggy (compared to 28rs) anyway... it wont matter. that turbo is going to be limited more by the turbine housing/wheel than the compressor, so just keep with the 28rs.</TD></TR></TABLE> 2871r doesn't lag much more if any compared to the same sized 28rs? I agree with the rest if you don't want lag get the .64... <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeGeND4LiFe &raquo;</TD></TR><TR><TD CLASS="quote">Threads about this always seem to go off topic. Does anyone actually know the performance differences between the different compressor housing options on the 2871r? </TD></TR></TABLE> Checkout http://www.freshalloy.com if you want to find out for yourself.
Old Aug 25, 2006 | 02:06 AM
Default Re: (turbozxi)
I searched there, didn't find any performance data on differences between the different compressor housings.
Old Aug 25, 2006 | 02:55 AM
Tony the Tiger's Avatar
You'll actually see improvement with the larger compressor housing. The main reason why the GT2871R has the smaller comp housing option is to become a direct bolt-on to existing GT28RS users. If you have the room to run the larger housing (if you are set on getting a GT2871R), you should go with the larger compressor housing
Old Aug 28, 2006 | 05:42 AM
JDogg's Avatar
Default Re: (Tony the Tiger)
the 71 compressor works ok on a sr20 b/c those things dont rev out like a honda does.. the 28 turbine chokes up real bad in the upper rpms. the 71 wheel is physicly a good bit bigger than the normal rs wheel, thus it takes a little more time to spool, transient response is nowhere near as good as the normal rs.
freaker
Aug 10, 2005 06:09 PM
dnbruut
Jul 8, 2005 07:57 AM
11psiTurboSI
Oct 13, 2004 06:23 AM
p1ccoloz
Jul 26, 2004 10:55 AM
DigitalFusion
Oct 30, 2003 06:13 PM
