B16 Hydro Tranny or replace my Stock GSR tranny with the same?
Old Feb 20, 2005 | 06:57 PM
yodas-gsr's Avatar
Default B16 Hydro Tranny or replace my Stock GSR tranny with the same?
hey guys,
my gsr tranny is going out, and im thinking about going to a b16 hydro tranny, for the shorter gearing, im supercharged and my specs are below by my signature... should i go with the b16 tranny, or stay and replace with a gsr tranny because it may be better for my S/C to have more time for boost? any suggestions?
thanks
late,
yoda
Old Feb 20, 2005 | 07:02 PM
underpressure02's Avatar
Default Re: B16 Hydro Tranny or replace my Stock GSR tranny with the same? (yodas-gsr)
did you search??? Seriously this is asked every day. If you plan on drag racing the car and don't care about driving it much on the highway then go with the b16 if you want some more top end stay with the gsr.
Old Feb 20, 2005 | 07:44 PM
yodas-gsr's Avatar
Default Re: B16 Hydro Tranny or replace my Stock GSR tranny with the same? (underpressure02)
thanks for the info, ill search again see if i can find what i want! but if not, im thinking about mostly drag and auto-x, i do drive on the freeway but not to much, and i dont mind going 60 65.
late,
yoda
Modified by yodas-gsr at 10:54 PM 2/20/2005
Old Feb 20, 2005 | 11:32 PM
yodas-gsr's Avatar
when you say top end, do you mean just mph or actual acceleration in the higher gears?
Old Feb 21, 2005 | 06:53 AM
Devine's Avatar
i noticed you have a lsd in your gsr tranny, correct me if im wrong but i was under the impression that gsr and b16 lsds were not interchangable. it might be worth getting another gsr tranny so you can swap in the lsd.
Old Feb 21, 2005 | 07:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yodas-gsr &raquo;</TD></TR><TR><TD CLASS="quote">when you say top end, do you mean just mph or actual acceleration in the higher gears?</TD></TR></TABLE>
Here is a quick example for you.
My gsr tranny at 80 mph is at about 4000 rpms if I remember correctly.
My ls tranny at 80 mph is at about 3200 rpms I think.
The b16 tranny at 80 mph will be above 4000 not sure of the rpms b/c I never owned a b16 tranny.
Old Feb 21, 2005 | 07:10 PM
yodas-gsr's Avatar
cool thanks underpressue!
yea devine i do have a quaife lsd, im thinking about just using the 'b16 gears' for lack of a better word, and put them in my gsr tranny...with the lsd...
thanks,
yoda
db8geezer
Oct 18, 2005 12:21 PM
92-EG6
30
Mar 14, 2004 06:18 AM
All Motor EG
Apr 25, 2002 07:29 PM
V8KILLA
Feb 10, 2002 11:47 AM
