will '00 itr exhaust fit on 96 GSR?
From my research on this board--because I've also been thinking about going with an ITR cat-back on my GS-R. . . .
JDM ITR exhaust = '94-'99 GS-R
USDM ITR exhaust = 2000-2001 GS-R
The flange holes will have to be enlarged on the JDM version to bolt to the cat, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS »</TD></TR><TR><TD CLASS="quote">You'll need to extend the B-pipe about 6 inches to reach your cat.</TD></TR></TABLE>so if i get the full exhaust system (cat, b pipe, and axelback), i'll still have to extend the b pipe? i thought there would only be problems bolting the cat to the stock gs-r header. please explain the length difference if both are coupes. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freshazzburu »</TD></TR><TR><TD CLASS="quote">... please explain the length difference if both are coupes. thanks</TD></TR></TABLE>There's different-length A-pipes.
Maybe you should modify your A-pipe (or add a spool-piece) & leave your cat & cat-back stuff alone. That way later you can get a header for a 2000 ITR so it matches the rest of your exhaust.
Isaac
Apr 13, 2002 02:36 PM
