misfire dealer cannot fix it
Old Feb 19, 2005 | 07:52 PM
dayaftertomorrow's Avatar
Default misfire dealer cannot fix it
I just have someone did a swap of a 2001 gsr into 2000 Lx civic. I use the 2000 si harness and 2001 gsr ecu. Random misfiring in 4 cylinder. Change the ignition wire. spark plug. distrubitor, and fuel regulator. Check the fuel pressure, injectors, map sensors, no problem with them. Then take it to the acura dealer and have valve adjustment. Still did not fix the problem. Don't know what to do. Need some serious help. Thanks
Old Feb 19, 2005 | 11:33 PM
EF-EF's Avatar
Default Re: misfire dealer cannot fix it (dayaftertomorrow)
check to see if the firing order on the distributor is in the correct sequence(1,3,4,2)
Old Feb 20, 2005 | 05:56 PM
Default Re: misfire dealer cannot fix it (EF-EF)
I swap a new distrubtor already. How can I tell the sequence? Thanks
Old Feb 20, 2005 | 07:47 PM
EF-EF's Avatar
the sparkplug wires might not be in the right sequence..is what I meant..(1,3,4,2)on distributor side...lower left as your looking at it is cylinder 1 and top of that is 3 and then right of 3 is 4 and then bottom of 4 is 2...hope you understand it...
Old Feb 20, 2005 | 09:01 PM
Default Re: (EF-EF)
The dealer replaced those for me and still have the same problem. They said they cannot fix it
Old Feb 20, 2005 | 11:05 PM
warrick's Avatar
Default Re: (dayaftertomorrow)
try a difference ecu, like an ITR or Si ecu, just to get it running and see if the misfire is present (not to ratbag it and pretend you're paul walker).
Old Feb 21, 2005 | 05:33 PM
Default Re: (warrick)
I tried the si ecu and still have the same problem. : (
xft
Jan 27, 2009 06:21 PM
sh_or_ty
14
Mar 13, 2008 06:46 AM
dayaftertomorrow
Feb 22, 2005 10:02 PM
dayaftertomorrow
11
Feb 20, 2005 05:54 PM
