manual vtec still work with to low oil??
I cant get my vtec to switch over, Right now I Have a 95ls ecu and the vtec solinoid wired straight to a hand held switch. when I hit the switch with the car off you can hear the solinoid working. but when Im driving and switch it dont work. could this mean that I dont have enough oil presure? I have a brand new itr oil/water pump, golden eagle vtec kit and everything else new form top to bottem running the smaller RSX filter also.
the oil level is fine the only other thing I can think of is me putting the valve train back in the rong order. I couldent find a diagram on how the vtec works so I just made educated guess
Excuse me, but how much oil press do you have? and i did what you are doing and it doesnt work, because when you connect a hand trigger you should disconnect the ecu line to the solenoid and the ecu throw a code and then vtec doesnt work until reconnect...hope will help.
See u
See u
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lventre »</TD></TR><TR><TD CLASS="quote">Excuse me, but how much oil press do you have? and i did what you are doing and it doesnt work, because when you connect a hand trigger you should disconnect the ecu line to the solenoid and the ecu throw a code and then vtec doesnt work until reconnect...hope will help.
See u</TD></TR></TABLE>
im running the ls ecu so it still runs fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">did you forget to put the 2 little vtec oil control thingys on the head?</TD></TR></TABLE>
na there both there brand new ones.
holy **** thats like 2 stages of fast and furious.....but u could just get a msd rpm activated switch when u figure out this little dilemma. Or my friend could chip your
ecu with uberdata and convert it to vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboostedvr6 »</TD></TR><TR><TD CLASS="quote">holy **** thats like 2 stages of fast and furious.....but u could just get a msd rpm activated switch when u figure out this little dilemma. Or my friend could chip your
ecu with uberdata and convert it to vtec.</TD></TR></TABLE>
the msd is lame bro and I had a p28 uberdata setup all ready but with no luck
have you tried revving the car to at least 3k and activating the switch while you hear if the sol. engages?.
if not do that and also measure vtec oil pressure from that oil port by the sol.
ya I tryed that and still no presure. meaby that means my solinoid is busted. Im gonna try one off my homies car
there is a dowel with an o-ring that goes underneath the center cam cap on all vtec b series motors that provides a restriction to allow enough oil pressure to push the pistons that engage the vtec lobe. if thats not installed or installed improperly vtec will not engage. In the past ive found that to be an issue with vtec not engaging.
Modified by areyoujealous at 9:39 PM 2/24/2005
hey thanks man for the help, but ya I got a new o-ring in there and mabey I could have wired it up rong I dont know. how I have it now is a wire from where your blue conector is to a switch and straight to the battery. dose that sound right? I guess you know me so who are you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DumpeDc2 »</TD></TR><TR><TD CLASS="quote">hey thanks man for the help, but ya I got a new o-ring in there and mabey I could have wired it up rong I dont know. how I have it now is a wire from where your blue conector is to a switch and straight to the battery.</TD></TR></TABLE>
hmm i don't know. I'm guessing your VTEC ecu isn't working right or you dont have one? Try a different VTEC ECU. as for hardwiring your VTEC solenoid to the battery, that's ghetto fabulous. Do you have a relay or fuse on it? WHat an easy way to burn it out. You want the VTEC ecu to adjust the fuel and timing maps, its not as simple as a trigger switch on your steering wheel fast and furious style.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I guess you know me so who are you?</TD></TR></TABLE>
Huh? I don't know you
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">sorry, have to ask; so you gave 12v to the sol. to activate it and then checked pressure and you get 0?</TD></TR></TABLE>
i'm his friend so i'll answer
Oil pressure to the head is at 0 no matter if the VTEC solenoid is on or off.
from idle to 6k rpm ... 0 oil pressure.
The motor seems to be running fine (with the exception of vtec) so its weird
The gauge is mounted on the head, right by the vtec solenoid in the hole facing towards the radiator.
Could the RSX oil filter be causing anything weird?
94wip
12
Jun 20, 2024 07:23 PM
SPOONfdEK
Jun 16, 2003 08:06 PM
