power window help
wats up guys.. i have an ej1 and lately the passanger side window will come back up all slow.. it will go down perfectly but it will go up hella slow.. i would search but i wouldnt know wat to search for.. please help me out.. tia
Your "runchannel" is sticking most likely causing the window motor to bind. Spray some silicone in the rubber track the window rides in to free it up...
If you keep straining the window motor,eventually youll need a new one...
If this doesnt work or your window makes popping noises and seems to come off track, you need a new window regulator...
Spray all the window tracks w/ silicone as preventive maintenance
autoparts store should have it, its in a can like spraypaint. Any generic spray silicone should work. The autoparts store guy should know what it is and be able to help you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem »</TD></TR><TR><TD CLASS="quote">Your "runchannel" is sticking most likely causing the window motor to bind. Spray some silicone in the rubber track the window rides in to free it up...
Spray all the window tracks w/ silicone as preventive maintenance </TD></TR></TABLE>
so do i have to take off the door panel?? or how would i go about doing this?? thanks man
no, just roll the window all the way down...
See the rubber "track" in which the window slides up and down in? This is called the runchannel...
That is where you need to spray the silicone spray....
aight aight i gotta bring this back from the dead cuz i still havent done it and i was gonna do it today but i didnt find any silicone spray.. anymore suggestions??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Proglow3 »</TD></TR><TR><TD CLASS="quote">Try looking for some white lithium grease or just ask some one at the parts store. I recommend you clean the tracks of the old grease too. Good luck.
so where would i put the lithium grease.. that **** is like used for everything but where would i put it??
</TD></TR></TABLE>so where would i put the lithium grease.. that **** is like used for everything but where would i put it??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecenjun »</TD></TR><TR><TD CLASS="quote">help</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macsmurray »</TD></TR><TR><TD CLASS="quote">This is honestly your best bet, if you can't find it in a hardware store, order it online. Loads of places sell it.
soo all i do is roll the window all the way down.. then spray down there?? or is it more complicated than that?? oh and right now the inside panel is off cuz i was messing with my mirrors.. so seeing as i had a problem with the window i might as well leave the panel off till i fix it.. hopefully today
soo all i do is roll the window all the way down.. then spray down there?? or is it more complicated than that?? oh and right now the inside panel is off cuz i was messing with my mirrors.. so seeing as i had a problem with the window i might as well leave the panel off till i fix it.. hopefully today</TD></TR></TABLE>
Thats exactly what you do. Wind the window fully down, and point the straw down the channel back and front edge of window (same straw as WD40) and spray. Then wind the window up and down a few times, it worked for me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macsmurray »</TD></TR><TR><TD CLASS="quote">Thats exactly what you do. Wind the window fully down, and point the straw down the channel back and front edge of window (same straw as WD40) and spray. Then wind the window up and down a few times, it worked for me!
yeah i just did that like not to long ago.. haha.. i was getting tired of waiting so i experimented.. it made it a little faster.. not as fast as the drivers side but faster than wat was going on before.. thanks guys
</TD></TR></TABLE>yeah i just did that like not to long ago.. haha.. i was getting tired of waiting so i experimented.. it made it a little faster.. not as fast as the drivers side but faster than wat was going on before.. thanks guys
hey i had this same prob on my ej. i took off the door panel took out the window and the black rubber in the tracks. then very carefully spread the tracks open just a little bit. not too much or your window will rattle. now my windows are super fast, even faster then when it was new. give it a try you wont be dissapointed.
hondaEg_808
Nov 30, 2010 12:35 AM
MiracleWhip
Dec 20, 2007 04:49 PM
EX-T
Dec 2, 2003 03:53 PM
