Name this rear bumper
Whne i looked at it first i thought it was a 98spec ITR bumper but it didnt look right, it is raked sharper at the sides than the 98spec and the little lip/diffuser is different also...anyone know what it is? the bottom pic i sthe regular 98spec bumper.
Heres a front end picture of the same car, i'm presumming the front bumper is also Crowhouse? Its sweet as hell, i prefer it to the mugen JDM bumper. (Sorry about the small pics, theyre taken from a JDM auction site)
You gotta love JDMism translation taken from their page re: the front under bumper panel
Quote: It is a form in consideration of the effect on rectification at the bottom of the reception desk, the decrease in lift, the occurrence of downforce, and so on.Then, a side part takes the form which leads air upward, and has effect on cooling to the brake by this, too.The elasticity against the strength when it was attached, and a twist and a deviation is the composition that a thing in high-speed running was fully taken into consideration.Stability in high speed improves securely when this under-panel is attached.Moreover, a maintenance side was taken into consideration, too, and made the cover type that a quick zipper was used for the part of the jack up point.It is that it is put on easily with a minus driver and taken off and it can be done.A jack for the business can be used, too.
