Please help me!!!@#$%^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost »</TD></TR><TR><TD CLASS="quote">Just run an FMU.
The hack sucks.</TD></TR></TABLE>
Just as bad as the FMU.
You're gonan need to upgrade to alrger injectors in order to use the AFC properly.
I've been runningon the AFC jsut fine for 11PSI for fuel management. I've chipped my ECU and replotted the IGN tables to coutner the timing advace that the AFC does so really, if you know what you are doing, It's pretty good for a basic management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">
Just as bad as the FMU.</TD></TR></TABLE>
Nope, it's definitely worse.
It actually advances your timing right at the boost transition.
In your opinion.
In your opinion.
It actually advances your timing right at the boost transition.</TD></TR></TABLE>
Like I said, if you know what to do with it, then it can be safe. My timing is stock and provides boost retard on the AFC hack. Just ahve to learn where you are palced in the IGN tables then worka ronud taht so you can acutalyl provide bosot retard even if the ecu thinks your in vacuum
well turns out the dsm injectors cant fit into the k24 motor. on the fuel rail side the injector is way too small and on the intake manifold the injector is way too big..so im guessing we got to buy new injectors like rc huh?
integranator
Mar 9, 2003 06:16 AM
TurbothisLS
Aug 25, 2002 05:39 PM
