VTEC wiring question???
Ive' been serching for a while but haven't really found anything solid.
I bought a 94 honda civic hatchback cx recently, and It already have a single head vtec motor swapped in it. My question is: I want to put a 2000 gsr motor in the car do I have to do anything else to the wiring so the motor can work, or is it simple plug and play???? Also I want to run an P28 computer that I have instead over the obd2 p72 comuter. Do I have to get an obd2-to-obd1 piggy-back in order for the motor to run correctly??? All help is greatly appreciated,AND I want to say thank u ahead of time to who ever can help me with this question.
that's not all necessarily true...
If your motor comes w/the "00 gsr wiring harness then you ARE able to plug in the gsr harness to your cx harness. That's my suggestion...F the obd-1 conversion junk...oh yeah almost forgot if you end up keeping the GSR mani you need to wire up the iab's to the ecu.
So i suggest switching to a blox or skunk2 or whatever is single runners so you wont have to worry bout wiring anything else up.
This is what i have done to my 94cx hatch.. swap the mani, p28, wire up the vtec solenoid and pressure switch..call it a day.
RC_Benjamin
Mar 14, 2006 05:44 PM
00ITR-0723
11
Feb 10, 2004 10:18 PM
