VTEC HEAD what to pick????
Old Feb 19, 2005 | 07:54 AM
CRVtec95's Avatar
Default VTEC HEAD what to pick????
I have 95 integra with B20b was thinking about going vtec. I hear that B16 flows better than B18 GSR head. What do u guys think is this true.
Also a lot of GSR owners drop in CTR cams. Why is that a good idea?
THanx
Old Feb 19, 2005 | 09:10 AM
D-Rob's Avatar
Default Re: VTEC HEAD what to pick???? (CRVtec95)
To answer your first question, technically, yes, the PR3 (B16) head flows better, but not by a whole lot. It's mostly in the higher RPM ranges.
If I were you, I'd choose a GSR head. Because of its pent-roof chamber design, it will yield higher compression.
As for your second question, CTR cams are the most aggressive OEM B-series cams available. They offer good mid-to-high end power and retain a perfectly smooth stock idle. They're a good bit more aggressive than stock GSR or B16A cams.
Old Feb 20, 2005 | 12:18 PM
CRVtec95's Avatar
Default Re: VTEC HEAD what to pick???? (drobinson)
Thanx for the good info
Old Feb 20, 2005 | 12:29 PM
Terrible One's Avatar
the p72 head also has larger intake/exhaust ports, from what i've heard. for ctr cams but make sure to upgrade the valvetrain to type-r or better.
SR20S13
Feb 23, 2010 06:27 PM
1JDMDOMINICAN
Mar 7, 2007 05:57 PM
ThatsMyEG
15
Dec 31, 2004 02:32 PM
PotatoePAPA
Jun 3, 2003 05:26 PM
Houston Hatchback
Apr 24, 2002 12:02 AM
