ctr cams in lsvtec turbo what you all think
Old Feb 19, 2005 | 04:21 AM
1.8turbolsvtec's Avatar
Default ctr cams in lsvtec turbo what you all think
just wanted to what you all think becaust this is the best place for info and maybe someone else has donr it .i got the cams in a trade for some motor work i did
and thanks to every one that looks at this post
Old Feb 19, 2005 | 04:49 AM
Madness's Avatar
Default Re: ctr cams in lsvtec turbo what you all think (1.8turbolsvtec)
Don't know about ctr, but people have run itr cams with great success
in big hp turbo cars.
Old Feb 19, 2005 | 07:42 AM
Default Re: ctr cams in lsvtec turbo what you all think (Madness)
thanks anyone else
Old Feb 19, 2005 | 07:43 AM
thanks anyone else
Old Feb 19, 2005 | 08:14 AM
Tchleung's Avatar
I ran ITR spec grinds on my stock b16. Boy was it a nice kick in the pants when VTEC engaged comapred to my setup now with stock cams.
Old Feb 20, 2005 | 08:45 AM
Default Re: (Tchleung)
thanks but know one has used ctr on there turbo lsvtec
Old Feb 20, 2005 | 08:54 AM
Luke J's Avatar
Default Re: (1.8turbolsvtec)
What turbo? How much boost do you plan on running? What rpm do you plan on spinning this to?
-Yes the CTR cams will work very well in the right application
Old Feb 20, 2005 | 03:21 PM
Default Re: (Lucky925l)
it is a fully built lsvtec 17 to 20 psi and the turbo is a super 60 60 /63 ar and what ap do you think they will work with o ya and i am reving it to 8200
Old Feb 20, 2005 | 05:14 PM
1.8EG-T's Avatar
The only thing that I would check is the piston to valve clearance, alot of people had piston/valve merging/smashing when they put ctr/itr cams in lsvtec with ls pistons, basically are your valve reliefs big enough to handle it.
Old Feb 21, 2005 | 08:21 AM
Default Re: (hybridrex)
thanks
vtechjunkie
May 24, 2009 06:46 PM
AmbiguousCivic
Aug 3, 2007 10:35 PM
spooledex
May 29, 2004 10:41 AM
mitch83
Feb 24, 2004 01:54 AM
Fuzion
Feb 24, 2004 12:05 AM
