16 x 7.5 will they rub on an eg with a 2.25 - 2.5 drop?
Old Feb 18, 2005 | 05:17 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default 16 x 7.5 will they rub on an eg with a 2.25 - 2.5 drop?
i am getting ready to order my RG's and will a 16 x 7.5 rub on a 2.25 - 2.5 drop? the springs are neuspeed pro drops. they only offer 5 on 114.3 in a 16 x 7.5. well thats all i see on gruppe-s. i hope they wont rub because if they do, ill just have to go with a ss tein set-up.
Old Feb 19, 2005 | 03:34 AM
Mr. Badwrench
Default Re: 16 x 7.5 will they rub on an eg with a 2.25 - 2.5 drop? (boostedcivicsir)
bump
Old Feb 19, 2005 | 04:27 AM
4drmadness's Avatar
you should be fine w/ that size rim on a 2-2.5drop. Any wider or bigger you may have problems.
Good luck...
Old Feb 19, 2005 | 05:18 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (4drmadness)
it will all depend on the offset of the wheel as well.
Old Feb 19, 2005 | 05:25 AM
Mr. Badwrench
Default Re: (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">it will all depend on the offset of the wheel as well.</TD></TR></TABLE>
looking at gruppe-s.com it looks like 45mm offset.
http://gruppe-s.com/Advan/advanrg.htm
5 on 114.3 16 x 7.5
Thanks Guys.
Old Feb 19, 2005 | 10:16 AM
Mr. Badwrench
Default Re: (boostedcivicsir)
bump
Old Feb 19, 2005 | 10:21 AM
cxSHOE's Avatar
if you run 7.5 wide rims i assume your going to be using 215 tires? 205's will be stretching it
7.0=205
7.5=215
8.0=225
etc.
Old Feb 19, 2005 | 10:33 AM
Mr. Badwrench
Default Re: (cxSHOE)
i was gonna stay with the overall diameter the same as my 195-50-15's.
Old Feb 19, 2005 | 10:37 AM
VtecCivicOnDaRun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">if you run 7.5 wide rims i assume your going to be using 215 tires? 205's will be stretching it
7.0=205
7.5=215
8.0=225
etc.</TD></TR></TABLE>
Go with the above sizes, 205 on 7.5 widths will work but it gives the rim no lip protection at all which = to bent lips all the time.
phuster
Jun 27, 2006 12:44 PM
FlipSkater
Aug 28, 2004 10:14 PM
JunIntegra
Jan 24, 2004 11:20 AM
mamaboy
May 6, 2003 03:23 PM
DerangedEG
Nov 24, 2002 05:57 AM
