10's stock block N/A FWD
Old Feb 18, 2005 | 02:46 PM
Hondog's Avatar
Default 10's stock block N/A FWD
I'm interested in how many people have run 10's N/A using a factory block and factory Bottom end. eg Factory rods, pistons, crank, sleeves, etc..
I'm interested in this since I hope to acheive this in the next weekend if the track conditions are good and the car makes the right amount of power. But I'd like to know how far into the 10's N/A's have gone on a Factory block set-up?
Old Feb 18, 2005 | 03:30 PM
4piston's Avatar
Default Re: 10's stock block N/A FWD (Hondog)
I'm assuming you are including race chassis also. Norris went 10.9 in his Insight with a stock bottom K20 on alcohol.
Old Feb 18, 2005 | 05:22 PM
MrParks's Avatar
11.0 @127mph is the closest ive got on a stock ls block 2550lbs in a integra
Old Feb 18, 2005 | 05:35 PM
TurboJesse
Guest
Posts: n/a
Default Re: 10's stock block N/A FWD (GHOSTWORKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GHOSTWORKS &raquo;</TD></TR><TR><TD CLASS="quote">11.0 @127mph is the closest ive got on a stock ls block 2550lbs in a integra </TD></TR></TABLE>
na
Old Feb 19, 2005 | 02:26 PM
SpdFrk's Avatar
How much power are u making? setup?
Old Feb 20, 2005 | 10:23 AM
MadnessRacing's Avatar
Default Re: 10's stock block N/A FWD (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">
na</TD></TR></TABLE>
no... it was turbo...
Old Feb 20, 2005 | 10:29 AM
TurboJesse
Guest
Posts: n/a
Default Re: 10's stock block N/A FWD (MadnessRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadnessRacing &raquo;</TD></TR><TR><TD CLASS="quote">
no... it was turbo...</TD></TR></TABLE>
i know...the original posts asks for NA setups..
Old Feb 21, 2005 | 01:40 PM
FormulaGSR's Avatar
Default Re: 10's stock block N/A FWD (Mpir3)
still curious as to how much power you were making
Old Feb 22, 2005 | 08:56 PM
MrParks's Avatar
Default Re: 10's stock block N/A FWD (FormulaGSR)
392hp 320ft lbs tq 15lbs of boost on a sparks turbo bolt on kit. sparks racing can vouch for that 24.5''x8x13 slick on ctr trans
Big Josh
Sep 22, 2009 05:25 PM
KiNG $h!t
49
Jan 7, 2008 04:39 PM
spoolinup
Jul 12, 2006 01:50 PM
bigapple427
Jul 12, 2005 10:15 AM
ITR97-143
Jul 23, 2004 04:16 PM
